1995-1997 Accord V6. 2 door? Any maunal tranny?
Did they make that shape accord in a V6 two door?
Also is there any manual transmissions that will bolt up to this motor, and fit in that chassis for me to be able to make the V6 stick shift?
Im not totally sure about them having a 5th gen coupe V6 but I could be wrong. You can swap in the 5spd tranny from the 1g legends. They use the same c27 engines. There's one done on here already. Search and you shall find.
The 1st V6 Accords were 5th Gens ('96 & '97's) were specific built chassis for the V6 installation. I would have to infer by the select-ability of vehicle info on the Majestic Honda Parts web site; that it was available* in both Automatic AND Manual Transmission configurations.
Unfortunately, the V6 WILL NOT fit in the 4cyl chassis without considerable massaging.
P
*subject to confirmation
P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams »</TD></TR><TR><TD CLASS="quote">The 1st V6 Accords were 5th Gens ('96 & '97's) were specific built chassis for the V6 installation. I would have to infer by the select-ability of vehicle info on the Majestic Honda Parts web site; that it was available* in both Automatic AND Manual Transmission configurations.
P
*subject to confirmation</TD></TR></TABLE>
Well I am not trying to put a V6 into another Accord. I am thinking about buying a 96-97 accord, and I would like to buy it V6 if i can, and I would like if they have it in a coupe. I also would like for it to be manual, but I never seen a manual V6 accord until 2002
P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Power Rev Racing »</TD></TR><TR><TD CLASS="quote">
Well I am not trying to put a V6 into another Accord. I am thinking about buying a 96-97 accord, and I would like to buy it V6 if i can, and I would like if they have it in a coupe. I also would like for it to be manual, but I never seen a manual V6 accord until 2002</TD></TR></TABLE>
i don't think there's a coupe v6, nor there's manual(within the states)
the front end of the car is different from 4 cylinder, which means good luck finding aftermarket part for it.
i don't know the exact weight number but you can search edmunds.com.
v6 auto sedan is slower than 5speed 4cylinder accord in the same generation.
accord v6 didn't come with an auto until 03
I stand corrected; furthur research reveals the V6 version of the 5th Gen Accords was available only as an Automatic.
My source calls out a curb weight of 2855 lbs for both Coupe and Sedan w/4cyl engine options.
I'd suspect the V6 version was several hundred pounds heavier (at about 3055 lbs) since it was an Iron 2.7L V6 (rather than the later aluminum engines)
It was rated at 170hp / 165ft/lb Torque
P
refer: http://auto.consumerguide.com/...specs/
P
Destructosaur
May 13, 2005 11:23 AM
rotax48
Feb 21, 2005 02:55 PM
