$225 to replace front wheel bearing; reasonable?
Old Dec 13, 2005 | 11:05 AM
onyx00's Avatar
Default $225 to replace front wheel bearing; reasonable?
Basch Acura found my wheel bearing was bad; they tighetened and said I could leave it and see how it is but the damage is probably done. Since I have a drive to Vegas in about two weeks, I am guessing I want to get it fixed before then.
They quoted me $73.50 for the wheel bearing, and then $150 in labor. So about $225 out the door.Does this sound reasonable?
Or is this something I could do on my own in a day? I have a completely free weekend, but I am not sure how involved replacing teh bearing would be.
Old Dec 13, 2005 | 11:09 AM
Bbasso's Avatar
Default Re: $225 to replace front wheel bearing; reasonable? (onyx00)
Judge for yourself...
https://honda-tech.com/zerothread?id=720159
Old Dec 13, 2005 | 11:11 AM
BlueR's Avatar
pay the 225, have a beer
wheel bearing installs
Skelly's Avatar
Do you have a Press?
Old Dec 13, 2005 | 11:12 AM
Skelly's Avatar
Default Re: $225 to replace front wheel bearing; reasonable? (B!b!a!s!s!o!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B!b!a!s!s!o! &raquo;</TD></TR><TR><TD CLASS="quote">Judge for yourself...
https://honda-tech.com/zerothread?id=720159</TD></TR></TABLE>
damn you beat me to it
Old Dec 13, 2005 | 11:13 AM
AssPenny's Avatar
Default Re: $225 to replace front wheel bearing; reasonable? (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">pay the 225, have a beer
wheel bearing installs </TD></TR></TABLE>
****, save 200 and have a beer Remove the knuckle yourself and take it to get the new bearings pressed in for $25. Spend the other $200 on stripers and drugs
Old Dec 13, 2005 | 11:14 AM
Bbasso's Avatar
Default Re: $225 to replace front wheel bearing; reasonable? (AssPenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">****, save 200 and have a beer Remove the knuckle yourself and take it to get the new bearings pressed in for $25. Spend the other $200 on stripers and drugs </TD></TR></TABLE>
That has to be the best thought ever!!!
Old Dec 13, 2005 | 11:15 AM
BlueR's Avatar
225 includes the part dufus...
they are only charging him 150 for labor
Old Dec 13, 2005 | 11:19 AM
ebelp's Avatar
You can get the wheel bearing much cheaper from Len.
Old Dec 13, 2005 | 11:24 AM
R you serious's Avatar
corner 3 garage takes care of my all my wheel bearing needs.
Stock Steve
chris, maybe you can press it in your self if you balance the bearing on your hub on a jack under your car and then just jack it up
Old Dec 13, 2005 | 11:28 AM
onyx00's Avatar
Default Re: $225 to replace front wheel bearing; reasonable? (R you serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious &raquo;</TD></TR><TR><TD CLASS="quote">corner 3 garage takes care of my all my wheel bearing needs.
Stock Steve
chris, maybe you can press it in your self if you balance the bearing on your hub on a jack under your car and then just jack it up </TD></TR></TABLE>
Corner 3 garage?
I know I could find a place to do the pressing for $25, but the part is still $75. I could order from Len, but I kind of want/need this before my long hard drive to Vegas.
What happens if I don't fix the bearing before such a drive? Any risk/worries??
Old Dec 13, 2005 | 11:30 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
I'm gonna go with Craig, remove hub your damn self, then take it to someone with a press. And say no to drugs
Old Dec 13, 2005 | 11:31 AM
Dave_B's Avatar
^^^ says Jim
Old Dec 13, 2005 | 12:04 PM
whitelightning's Avatar
diy...strippers and beer
Old Dec 13, 2005 | 02:21 PM
JDM Factor's Avatar
Strippers...where!?
Old Dec 13, 2005 | 02:40 PM
ATgrills.com's Avatar
Default Re: (JDM Factor)
damm i must undercharge, cuz i only charged like 150$ca for the last customer!
Old Dec 13, 2005 | 03:09 PM
RCautoworks's Avatar
Default Re: $225 to replace front wheel bearing; reasonable? (Skelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skelly &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a Press?
https://honda-tech.com/zerothread?id=720159 </TD></TR></TABLE>
You can do it with a slide hammer, and no it will not ruin anything.
Old Dec 13, 2005 | 05:58 PM
Default Re: $225 to replace front wheel bearing; reasonable? (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
You can do it with a slide hammer, and no it will not ruin anything.</TD></TR></TABLE>
rorz your out of your mind if you think yoiu can do it with a slide hammeR
is it possible?... yes.
Can he do it? no chance in hell.
Old Dec 13, 2005 | 06:33 PM
Haleiwa-Brando's Avatar
You can get two new wheel bearings from Autozone for $160.00. Installing them is super easy. Right Jeremy?
Old Dec 14, 2005 | 08:09 AM
onyx00's Avatar
Default Re: $225 to replace front wheel bearing; reasonable? (Haleiwa-Brando)
Screw it, I am having Basch do it on Friday since they are also doing one of my motor mounts.
Old Dec 14, 2005 | 10:39 AM
Can he do it? no chance in hell. </TD></TR></TABLE>
I can do it, and a lot of other people do it. I have seen people at Honda using the same method.
Old Dec 14, 2005 | 11:39 AM
743power's Avatar
wheel bearing - $50
domestic guy at the corner shop pressing in a new one on your removed knuckle - $20
remove/replace knuckle yourself - cost of bandaids and beverage of your choice
knowing that you saved yourself $150 - priceless
Old Dec 14, 2005 | 04:54 PM
and you use a bearing splitter with the slide hammer as well?
Old Dec 14, 2005 | 05:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious &raquo;</TD></TR><TR><TD CLASS="quote">and you use a bearing splitter with the slide hammer as well? </TD></TR></TABLE>
No, you use a pitman arm puller to separate the ball joint. But if you use a slide hammer, you don't have to separate the ball joints.
Old Dec 14, 2005 | 05:15 PM
no no, i was talking about getting the inside bearing casing off the hub after the bearing seperates
