ok b16 revert question
Old Dec 13, 2005 | 08:38 AM
Down Shift Motoring's Avatar
Default ok b16 revert question
alright. my friend has b16 in his crx and is currently unhappy with how it is performing. he just bought it and it isnt pushing the power it should. i got took by a stock rsx type s and i should have beat it by atleast 2 cars with the stuff he has. Okay heres my question we want to take off the GSXR ITB setup, the eriks racing reburn ecu, wrx injectors are currently installed but dont know if should leave in or take out replace with b16 injectors, also the o2 sensors have been changed to bosh 1 wire o2s do these need to be replaced, finally take out the stand alone fuel system (mega squirt). What do we need to buy to do this. The ecu we want to use is spoon pw0.
Old Dec 13, 2005 | 08:56 AM
Default Re: ok b16 revert question (ef9typer)
bump
Old Dec 13, 2005 | 09:26 AM
EP3_05's Avatar
Ok you will need a b series intake manifold and throttle body. I would replace the injectors with stock honda peak and hold injectors (240cc). I am running 2 bosch sensors on my b16a with no problems so unless the O2 sensors are fouled there is no reason to replace them.
My only question is has the engine been tuned for the itbs?? They can be difficult to tune and you might want to try to have it tuned before you go ahead and rip the system out.
Old Dec 13, 2005 | 09:27 AM
g24jr's Avatar
lol is that a water bottle?
Old Dec 13, 2005 | 09:29 AM
Default Re: ok b16 revert question (g24jr)
is what a water bottle ????? can anyone seriously help?
Old Dec 13, 2005 | 09:32 AM
Default Re: ok b16 revert question (91civic)
havent had it tuned yet. we really wanna replace the stand alone fuel injection (mega squirt) i dont want to have to program the stuff that a good programmed ecu already does for you.
Old Dec 13, 2005 | 09:45 AM
Jesterian's Avatar
24.243.141.75
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g24jr &raquo;</TD></TR><TR><TD CLASS="quote">lol is that a water bottle?</TD></TR></TABLE>
Looks like an upside down aquafina
Old Dec 13, 2005 | 10:02 AM
Default Re: ok b16 revert question (Jesterian)
actually if you are refering the thing with bubble wrap thats the stock harness for b16 injectors we have ready incase the wrx injectors fail we can plug and play with b16. smart move no need to knock.
Old Dec 13, 2005 | 01:22 PM
Captn Shakelford.'s Avatar
what internals have you done to support itbs? you need to have it tuned, then make a call about going back to intake mani and tb. just my .02
Old Dec 13, 2005 | 04:37 PM
mrtoastyjr's Avatar
someone correct me if im wrong, but those O2 sensors look awfully close to the head
Old Dec 13, 2005 | 04:39 PM
Sleepy_Red_hatch's Avatar
Default Re: ok b16 revert question (DOHC_SLOW)
tune tune tune
get the ITB's tuned before you decide!!
Old Dec 13, 2005 | 04:50 PM
Pee Wee's Avatar
Default Re: ok b16 revert question (mrtoastyjr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrtoastyjr &raquo;</TD></TR><TR><TD CLASS="quote">someone correct me if im wrong, but those O2 sensors look awfully close to the head</TD></TR></TABLE>
yeah i dont know why they are running em so close
Old Dec 13, 2005 | 05:03 PM
SD_Lurker's Avatar
HT White Ops
Default Re: ok b16 revert question (EF8opey)
I agree. You need to have this tuned. You can not just put these on and call it a day. It takes time to have these dialed in right. if you were tuned you would have walked that rsx.
Old Dec 14, 2005 | 01:59 AM
badboyr66's Avatar
Default Re: ok b16 revert question (nicks_jdmstyle_ef9)
go find a real tuner... you know you found a real one cause you will pay alot of money. Go to a dyno and let the tuner tune it.
Old Dec 14, 2005 | 08:24 AM
InEK's Avatar
I tried to get it tuned...no success there arent too many places out here that will even touch it (Northern Indiana) I bought the car how it is and question how efficient the fuel management is (megasquirt) Its definately not tuned well...the ITBs are playing as if they were a regular intake. The other problem is my vtec...everything is hooked up...but it barely hits. I plan on just getting rid of ITB's and management and doing everything myself to be sure of what i have...i wont have to worry about tuning it properly all the time.
Old Dec 14, 2005 | 08:26 AM
InEK's Avatar
oh also... on the 02's only one is hooked up...i couldnt even begin to tell you why(just made it efficient for the management)..but there are no engine lights
Old Dec 14, 2005 | 09:30 AM
Pee Wee's Avatar
Default Re: (BlackEF8)
i feel your pain on the indiana part. do what i did. move far away.
there are tuners out there you just have to be willing to take a couple hour road trip
Old Dec 14, 2005 | 12:20 PM
Freemantle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9typer &raquo;</TD></TR><TR><TD CLASS="quote">havent had it tuned yet. we really wanna replace the stand alone fuel injection (mega squirt) i dont want to have to program the stuff that a good programmed ecu already does for you.</TD></TR></TABLE>
Remove your rev limiter and take out an indescriminate amount of fuel that isn't even close to tailored to your engine? ****, I could do that with my eyes closed. Fine a good uberdata tuner in your area or do it yourself. It's waaaay worth it. You don't have hardware problems, you just need a good tune.
Keep the ITBs.
Ditch megasquirt and the WRX injectors.
VTEC shouldn't "hit hard". If you feel a hard pull at x-over, then your VTEC is set wrong.
Old Dec 14, 2005 | 03:26 PM
mar778c's Avatar
Community Builder
Community Influencer
Bro,
Get it tuned. Unless that rsx-s was b'sing, there is no way it should have been close.
Also, what kind of mods are in this engine?
Old Dec 14, 2005 | 03:35 PM
ScorpioMk's Avatar
Default Re: ok b16 revert question (mar778c)
if you can find a megasquirt tuner try it. thats most likely what i would use if i was to put a 20v into my corolla and its what most people use when they swap a 20v and tune it. if you look on club4ag you might be able to find a tuner on there thats closer than you think. it is mostly a so cal website but people from all over are on it. cams and compression would probably really help the itb setup also. much more fun than reverting back to stock. unless you were going to boost it.
marcus
blasterman87
Oct 7, 2009 03:53 PM
91crx93civic
Engine Management and Tuning
Mar 22, 2009 07:51 AM
h2point2
Sep 17, 2007 07:56 AM
HondaCivicSiR1
Jun 16, 2004 07:20 PM
W0oT
Jun 13, 2002 05:41 PM
