help with mini me swap
88 crx si
a6 block 96 ex head.
getting code 3 dont have the solenoids from the firewall hooked up just the charcoal canister hooked up to the manifold,
car will not start without giving it alot of gas, and when it does it sounds like its way off timing and just dies.
what could the problem be
I'm pretty sure code 3 is the MAP sensor. You need to have that plugged in, otherwise you car will not run right, if at all. Make sure you have everything plugged in before trying to run your car.
Gabe Gamble
Aug 7, 2011 03:26 PM
crfr230
Apr 20, 2007 05:12 PM
