engine stutter
Old Dec 12, 2005 | 07:22 PM
error's Avatar
Default engine stutter
my 84 chevy van's engine stutters after i shut it off. any ideas as to why? i know its not a honda, sorry. its not even FI.
Old Dec 12, 2005 | 07:57 PM
onepoint6i's Avatar
Default Re: engine stutter (error)
do you mean it diesels? (turn the key off, it keeps running?)
Old Dec 12, 2005 | 07:59 PM
error's Avatar
Default Re: engine stutter (onepoint6i)
well its not a diesel. have you ever seen the original "friday" with cube, and chris tucker? well its like chris tuckers convertable pinto. i shut it off and it keeps sputtering with little backfires..... then stops after a few seconds
Old Dec 12, 2005 | 08:25 PM
Muckman's Avatar
Moderator in Chief
yeah thats called "disealing". The fuel is still combusting without any ignition.
Old Dec 12, 2005 | 08:29 PM
onepoint6i's Avatar
Default Re: engine stutter (Muckman)
yup a carb problem...just get rid of that thing, it wont pass smog anyways
Old Dec 12, 2005 | 08:36 PM
error's Avatar
wow, how the hell does that happen with out the plugs firing?
Old Dec 12, 2005 | 08:41 PM
onepoint6i's Avatar
excessive engine temp, also a defective jet cutoff valve (carb)..
simply it keeps delivering fuel to a very hot spark plug, in turn it doesnt shut off...
Old Dec 13, 2005 | 04:03 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by error &raquo;</TD></TR><TR><TD CLASS="quote">wow, how the hell does that happen with out the plugs firing?</TD></TR></TABLE>Carburators can still provide gas after the key's turned off. Some carbs don't even have a fuel shutoff valve.
Carbon buildup in the combustion chamber stays hot enough to ignite the mixture. Not very well, but just enough to do what you describe. Maybe clean it out with seafoam or something like that?
Old Dec 13, 2005 | 10:59 AM
error's Avatar
Default Re: engine stutter (JimBlake)
good info guys, thabks alot!
Dadragonlord289
Jan 25, 2015 03:17 PM
Jeffrey9
Apr 2, 2008 12:46 PM
msinsky14
Jun 8, 2006 05:50 PM
ginjw78
Jul 7, 2004 04:58 PM
