ARP ROD BOLTS Torque Specs
Old Dec 12, 2005 | 07:19 PM
CA6VTEC's Avatar
Default ARP ROD BOLTS Torque Specs
<FONT COLOR="royalblue"> I just picked up some eagle rods w/ the arp rods bolts, but they didn't come w/ the torque spec sheet.. I tried going to arp, but my shitty 56k is killing me. </FONT>
Old Dec 12, 2005 | 07:32 PM
onepoint6i's Avatar
Default Re: ARP ROD BOLTS Torque Specs (CA6VTEC)
what bolts did they come with? more than likely 5/16" ARP 2000-3/8" bolt head?
you should invest in a Rod bolt stretch gauge, much more accurate than a torque wrench for Arp rod bolts..
Old Dec 12, 2005 | 09:28 PM
Sliced Beard's Avatar
Default Re: ARP ROD BOLTS Torque Specs (onepoint6i)
I suggest you measure the rod bolt stretch and set them to ARP specifications. Call up ARP and they will give you the exact specification.
I have a stretch guage that I could set your stretch for you with but I am too far away. Your best bet is to either torque them to factory +2 ft-lb or send it off to the machine shop and have them measure it to proper stretch.
Old Dec 12, 2005 | 10:17 PM
budsmachine's Avatar
Default Re: ARP ROD BOLTS Torque Specs (DirtySol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtySol &raquo;</TD></TR><TR><TD CLASS="quote"> Your best bet is to either torque them to factory +2 ft-lb or send it off to the machine shop and have them measure it to proper stretch.</TD></TR></TABLE>
Do not torque to factory specs!!!!! most all eagle rods untill recently use 5/16 bolts (close to 8mm). factory b16 and b18c rods have 9mm bolts. if you torque to factory 33lbs you will over stretch the bolts possibly causing breakage. call eagle 662-796-7373, they will need to know the socket size of the head and the markings on the head(eagle8740 or eagleS2000 i think).
1993gsrcivic
May 21, 2008 11:51 AM
b20vtech
Apr 20, 2007 08:51 AM
EK FLY
Dec 31, 2004 06:18 AM
nortrop
Aug 16, 2004 06:03 AM
H22coupe
Apr 30, 2004 05:24 PM
