are ground control coilovers year specific?
Some shocks like Koni and Bilstein require specific sleeves. http://www.ground-control.com will answer all your questions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HdA1T6CzH6 »</TD></TR><TR><TD CLASS="quote">do i have to get g.c. coilovers for my car and year??? thanks....if not what would fit on an 88 civic hatchback besides its year g.c.</TD></TR></TABLE>
if you are getting only the coilover sleeves, not the complete coilover system, then you will need to get the coilovers sleeves for a 88-00 civic/94-01 integra, those are all the same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AUTOMATION GARAGE »</TD></TR><TR><TD CLASS="quote">if you are getting only the coilover sleeves, not the complete coilover system, then you will need to get the coilovers sleeves for a 88-00 civic/94-01 integra, those are all the same
The sleeves are all the same, but the spring rates will be different. If you do order a set from another car, make sure they are the spring rates you want. If you order them directly from ground control, you can order any custom spring rates you want though...
</TD></TR></TABLE>The sleeves are all the same, but the spring rates will be different. If you do order a set from another car, make sure they are the spring rates you want. If you order them directly from ground control, you can order any custom spring rates you want though...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alex@AutomationGarage »</TD></TR><TR><TD CLASS="quote">if you are getting only the coilover sleeves, not the complete coilover system, then you will need to get the coilovers sleeves for a 88-00 civic/94-01 integra, those are all the same
</TD></TR></TABLE>Well that doesn't make sense? I know from personal experience that 88-91 civic and 90-93 integra were the same. 88 has different rear shocks though. I have a problem of my own though. I prob need to start my own thread though
99redSIR
May 10, 2004 12:34 PM
