92 EG Hatch side molding holes??
Old Dec 12, 2005 | 06:04 PM
b16hatche's Avatar
Default 92 EG Hatch side molding holes??
i was wondering if anyone knew about what it would cost to have my side molding holes filled in by a body shop or the easiest way for me to do it myself. should i not bondo it and try to weld in little squares of metal or what?(would jb weld be ghetto) and about how much it would cost
Old Dec 12, 2005 | 06:11 PM
nitekidsef9's Avatar
Default Re: 92 EG Hatch side molding holes?? (b16hatche)
if i were you id just ask around your town for a place thats done "tuner" jobs.
any decent shop should be able to quote you if you drop by
Old Dec 12, 2005 | 06:19 PM
b16hatche's Avatar
anyone know about doing it yourself, possibility of using jb weld (or would it fall out also like bondo) trying to figure out so i can get my car painted asap
Old Dec 12, 2005 | 06:43 PM
b16hatche's Avatar
no1 has ever done this themselves
Old Dec 12, 2005 | 06:44 PM
VRD^sam's Avatar
Steel metal and bondo=45.00
Old Dec 12, 2005 | 07:02 PM
Alchemist's Avatar
Tack weld a plate from behind, then bondo on top. I would just buy the CX or VX fenders and doors, save yourself the time and money.
Old Dec 12, 2005 | 07:34 PM
2'z kuztoms's Avatar
From: Streets of Sacramento...But now living in So Cal, usa
[QUOTE=b16hatche]no1 has ever done this themselves
yeah,me. but i work @ a bodyshop
Old Dec 12, 2005 | 10:01 PM
rlockwood's Avatar
Default Re: 92 EG Hatch side molding holes?? (Alchemist)
and how about the rear quarter panel?
anyone ever done the reverse? (installing moldings on vx/cx?)
Old Dec 12, 2005 | 10:43 PM
whoa its len 2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alchemist &raquo;</TD></TR><TR><TD CLASS="quote">Tack weld a plate from behind, then bondo on top. I would just buy the CX or VX fenders and doors, save yourself the time and money. </TD></TR></TABLE>
2nd that.
Old Dec 12, 2005 | 10:49 PM
JDM-EJ1's Avatar
Default Re: 92 EG Hatch side molding holes?? (nitekidsef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitekidsef9 &raquo;</TD></TR><TR><TD CLASS="quote">
any decent shop should be able to quote you if you drop by</TD></TR></TABLE>
I'd say this is your best bet.
Old Dec 12, 2005 | 11:53 PM
FURACERMAN's Avatar
Default Re: 92 EG Hatch side molding holes?? (rlockwood)
I saw a hatch that had moldings on one side, and none on the other.
Old Dec 13, 2005 | 08:38 AM
verycleanhatch's Avatar
Have you thought about the thin side moldings? Looks better than stock. On your sig it has cx. Cx don't have moldings.
Old Dec 13, 2005 | 08:45 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
This is what I was thinking. If it were me, I'd just put some JDM thin side moldings on and leave it.
Old Dec 13, 2005 | 09:35 AM
WishinItWas's Avatar
Default Re: 92 EG Hatch side molding holes?? (NAallTheWAY)
still leaves the rear 1/4 pannels to fill dont forget that
Old Dec 13, 2005 | 10:33 AM
aeon's Avatar
I did mine myself. I got some super hard metal to metal glue and glued on some metal plates behind each hole. Then applied bondo and sanded it down. Been on for a year now and no problems so far. Oh yeah, make sure you get some kind of sealant to spray over the metal pieces so they don't rust.
Old Dec 13, 2005 | 10:45 AM
solareclipseauto's Avatar
Default Re: (aeon)
tack weld sheet metal in place of the molding across the door to reduce any flex in the door that can possibly cause it to crack later. fill the rest with marglass or kitty hair(filler with fiberglass strands) sand it and then finish it with bondo.
Old Dec 13, 2005 | 10:47 AM
b16hatche's Avatar
Default Re: 92 EG Hatch side molding holes?? (nomorehatch)
i have seen those JDM thin side moldings but can only find them for the EK
Old Dec 13, 2005 | 01:36 PM
b16hatche's Avatar
would the ek side moldings work for my eg?
Old Dec 13, 2005 | 05:14 PM
b16hatche's Avatar
Default Re: (aeon)
[I did mine myself. I got some super hard metal to metal glue and glued on some metal plates behind each hole. Then applied bondo and sanded it down. Been on for a year now and no problems so far. Oh yeah, make sure you get some kind of sealant to spray over the metal pieces so they don't rust.] : Qoute by AEON
How did u glue metal plates on behind the door??? I wanna figure this out
Old Dec 13, 2005 | 05:38 PM
aeon's Avatar
Default Re: (b16hatche)
Okay, what you're doing is cutting up little square metal pieces that are larger than the holes on your door. From the inside, sand around the hole until you see bare metal. Make sure the diameter of the metal showing is about the size of the metal squares or bigger. Also I'm not sure if I did or not, but you should sand around the hole on the other side also. Now the glue I bought, was made to glue metal to metal. I forgot what it was called but I got it from an autobody shop. Costed me around 30-40 bucks. Make sure everything is clean, apply the glue to the metal plate and glue them to each hole. Some glue will ooze out to the other side but it's okay. The glue I had took a long time to dry so I had to apply tape over them to hold them up and after I finished all of the holes on one side, I used a heat gun to speed up the drying process. Once glue is dry which may take up to 24 hrs to cure, just sand down the excess glue that came through. Then you can do what solareclipseauto suggested and use marglass or kitty hair and apply that to the outside. Sand that down and then apply bondo to fill in any holes. That's it and now you can prep and then paint.
Old Dec 13, 2005 | 05:47 PM
b16hatche's Avatar
Default Re: (aeon)
thankx for the how-to but what i was trying to figure out was how to glue the pieces of metal to the inside of the door and rear quarter panels
Old Dec 13, 2005 | 05:53 PM
aeon's Avatar
remove door panels and rear panel. remove moldings and you'll see some holes. from there just do what i wrote before.
Dkahn18
Paint and Body
Feb 28, 2010 02:12 PM
patrickstar
Paint and Body
11
Jun 25, 2009 10:30 AM
4drferio
Jan 24, 2004 01:05 PM
tominos
Feb 7, 2003 01:40 AM
