IS my timing off? god damnit!
Old Dec 12, 2005 | 05:56 PM
civicdust's Avatar
Default IS my timing off? god damnit!
im having trouble timing my car. i line up exhaust and intake manifold cams, and when i try to put the belt on, the intake cam, moves, and its hard to get it back lined up.
its hard to explain. car runs slow. hesitated, blows white smokes, air filter makes a weird noise. and the exhaust fumes will like give u headache, cuz its smells so bad.
help me HT
Old Dec 12, 2005 | 06:20 PM
lastpunkinline's Avatar
Default Re: IS my timing off? god damnit! (Joon)
You sure the belt isn't hard to put on because u didn't loosen the tensioner? Or whatever its called???? Im pretty sure thats what its called
Old Dec 13, 2005 | 05:29 PM
civicdust's Avatar
Default Re: IS my timing off? god damnit! (lastpunkinline)
no its not that, i know how to time a motor. i think i put the intake cam wrong, when i put a new headgasket on
Old Dec 13, 2005 | 05:48 PM
thelate1's Avatar
can't you use pin punches through the cam caps to keep them tdc?.....
i thought there are holes for doing this, maybe not........
Old Dec 13, 2005 | 05:52 PM
civicdust's Avatar
Default Re: IS my timing off? god damnit! (thelate1)
i have no idea, i would have to check on my haynes
Old Dec 13, 2005 | 06:16 PM
sykotic's Avatar
There are, you push a nail or something through them to keep them TDC, then you put the belt on, its easy as hell..
Old Dec 14, 2005 | 09:46 AM
civicdust's Avatar
Default Re: IS my timing off? god damnit! (sykotic)
im gonna check it out when i get home. if it works, great. i will do it when i change my head gasket.
any tips for when changing headgaskets? mines blowing white smoke.
should i add copper spray? or something else?
backinblue92
Feb 22, 2015 06:57 PM
mike:
Oct 18, 2014 07:03 PM
Singha83
Jun 30, 2012 11:27 PM
integlstrike1
Aug 22, 2006 07:24 PM
JDMlyfestyle
Nov 24, 2004 04:48 PM
