7th gen recall cooling line
Old Dec 12, 2005 | 04:32 PM
BLKFLSH's Avatar
Default 7th gen recall cooling line
I just changed my trans fluid for the first time. Where the Helm manual says to fill the trans, it has a small hose going through a hole in the fill plug. I was just wondering if this was the added cooling line per the recall, or just something that wasn't shown on the shop manual, but was always there before they did the cooling line. 03EXV6
Old Dec 12, 2005 | 05:17 PM
Ross 2.0's Avatar
In a Junkyard near you.
you had it right. That's the second gear recall. That's a ATF pressure line designed to squirt fluid on the second gear to keep it well lubricated. The converse is a tooth breaking off and seizing the transmission.
Old Dec 12, 2005 | 05:19 PM
BLKFLSH's Avatar
Default Re: (MooGoCow3)
Thanks man. I was just guessing that's what it was, cause it didn't show in the manual.
DielsAlder
Aug 22, 2012 07:33 AM
bseriescrxsi
Oct 14, 2009 07:03 AM
smeltjr
Aug 17, 2008 10:09 PM
mgags7
10
Jan 20, 2006 07:23 PM
