My CRX symptoms
Old Dec 12, 2005 | 04:12 PM
scarface50370's Avatar
Default My CRX symptoms
89 CRX DPFI is throwing a code 7 witch is Throttle positon angle .......and it also bogs at low idle like when im taking off..only does this wen the car is warm...not while is cold...also is smoking a lil but of like whitish lil bluesih smoke......can any one help me the engine is a d15b2
Old Dec 12, 2005 | 04:18 PM
Default Re: My CRX symptoms (scarface50370)
Old Dec 12, 2005 | 04:22 PM
Louzerz's Avatar
Which one is it? White or blue. White means coolant is getting into your oil possibly meaning a blown or soon to be blown head gasket and blue means oil is burning up within combustion. First check if your losing motor oil or coolant or both.
Old Dec 12, 2005 | 04:33 PM
Default Re: My CRX symptoms (Louzerz)
oh ok i think the lest time i check i had no coolant at all..........so i put water...one question the code 7 would cause my car to bog like that right?
Old Dec 12, 2005 | 04:34 PM
NikoZai's Avatar
You may also get some backfiring if the butterfly is closed but the computer is firing the injectors as if it's 10% open. Smell like fuel?
Yeah that would cause a TPS code.
Old Dec 12, 2005 | 04:40 PM
Default Re: My CRX symptoms (NikoZai)
so if its the oil coolant getting through witchi think it is..what o i need to do??
Old Dec 12, 2005 | 04:48 PM
SiR Inspired ED7's Avatar
new head gasket
Old Dec 12, 2005 | 05:23 PM
its white smoke!!!!!!! either or i should just replace the head gasket??
Old Dec 12, 2005 | 05:25 PM
white smoke = bad headgasket = replace soon
Old Dec 12, 2005 | 05:35 PM
whee can i pick one up cheap?
Old Dec 12, 2005 | 07:05 PM
george34's Avatar
Default Re: (scarface50370)
What would the smell of gas mean? I have with smoke and smell gas.
you can get a metal headgasket for $30. Are the Mr. Gasket headgaskets like the best b/c they are like 60? What brands are the bad brands for headgaskets? Thanks
Old Dec 12, 2005 | 08:59 PM
square_1's Avatar
Go to any auto parts store. We just replaced the head gasket on my friends 91 Accord. It was a nifty looking gasket and like 30 bucks. Also when your car is still hot look under the oil filler cap, if there is a white milky substance that is for sure head gasket problems... Could also be that something is cracked, but we won't worry about that.
Topshot
Jan 7, 2012 06:15 PM
JUN.
Jul 11, 2007 06:56 AM
damnitamy
Oct 15, 2006 10:20 AM
blumpfish
Jun 18, 2006 09:23 PM
sambam27
Dec 5, 2004 09:39 AM
