Safe Boost?
Old Dec 12, 2005 | 03:37 PM
TurboEKcoupe's Avatar
Default Safe Boost?
i got a D16Y8 Single Cam motor with 90,000 miles on it and i just bought my turbo kit and got everything rolling but i had a quick question what do you guys think i can boost max at a safe level?
Old Dec 12, 2005 | 03:38 PM
G2 Speed's Avatar
Default Re: Safe Boost? (TurboEKcoupe)
6-8
Old Dec 12, 2005 | 03:39 PM
AMS Sean's Avatar
Default Re: Safe Boost? (G2 Speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed &raquo;</TD></TR><TR><TD CLASS="quote">6-8</TD></TR></TABLE>
agree
Old Dec 12, 2005 | 03:40 PM
petersayarath's Avatar
&lt;&lt;&lt;&lt; gsr with itr internals.. boosting 8lbs
Old Dec 12, 2005 | 03:41 PM
komat's Avatar
Default Re: Safe Boost? (AMS Sean)
what turbo size is it?
cant just say 6-8 without knowing what turbo it is
Old Dec 12, 2005 | 03:42 PM
thanks for all the fast replies guys! a friend of mine said he had a turbo single cam and was boosting at 9 no problem..he said d series are great for turbo is this true?
Default Re: (TurboEKcoupe)
Turbonetics T3/T4 Hybrid
G2 Speed's Avatar
anything is good to turbo......
unless it has mega high compression
Old Dec 12, 2005 | 03:45 PM
tallyturbo's Avatar
Old Dec 12, 2005 | 03:46 PM
thanks for all the help guys i will post pics when finished :D
Old Dec 12, 2005 | 03:50 PM
G2 Speed's Avatar
no problem good luck
Old Dec 12, 2005 | 03:52 PM
anony95ex's Avatar
Depends. What fuel system are you running? What PCM/tuning device? Do you have a wideband O2 sensor and display?
You'll have to get a dyno tune to be safe at any boost level. It'll also guarauntee you maximum power while remaining in the "safe" zone. If you install that turbo kit and cheap out by not paying for a proper tune, it'll never be as safe or as powerful as it could be.
Old Dec 12, 2005 | 10:38 PM
nekoabandoned's Avatar
Default Re: Safe Boost? (anony95ex)
just do 8-9 with a good tune chrome rocks!
Old Dec 12, 2005 | 11:01 PM
Turbo_EJ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anony95ex &raquo;</TD></TR><TR><TD CLASS="quote">Depends. What fuel system are you running? What PCM/tuning device? Do you have a wideband O2 sensor and display?
You'll have to get a dyno tune to be safe at any boost level. It'll also guarauntee you maximum power while remaining in the "safe" zone. If you install that turbo kit and cheap out by not paying for a proper tune, it'll never be as safe or as powerful as it could be.</TD></TR></TABLE>
with a good tune youll maximise what u can get safely outta it. I ran about 10 on stock internals but upgraded fuel system for over a year before i built everything right.
Old Dec 13, 2005 | 01:09 AM
808draggers's Avatar
I push 8psi daily on the same motor setup as you. Almost the same mileage too! As long as you got the right setup it should be good. My boy pushes 10 pounds daily and he's still going on 140,000 miles. About 20,000 miles boosted.
Old Dec 13, 2005 | 05:18 AM
Toroke's Avatar
Default Re: Safe Boost? (nekoabandoned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekoabandoned &raquo;</TD></TR><TR><TD CLASS="quote">just do 8-9 with a good tune chrome rocks!</TD></TR></TABLE>
Crome. It stands for Cui ROM Editor. It's really bothersome when people call it "Chrome."
Old Dec 13, 2005 | 05:24 AM
RACEPAK's Avatar
Default Re: Safe Boost? (Toroke)
check your compression and then decide....
Old Dec 13, 2005 | 05:35 AM
mrbigg9032's Avatar
Its all about tuning, u can totally destroy your motor on 3 pounds of boost expecially if its not tuned properly. 6-8 pounds is good for daily driving on a y8 if its tuned right Good luck. I love turboed single cams.
Old Dec 13, 2005 | 06:23 AM
Everyones Hero's Avatar
Default Re: (mrbigg9032)
With an "okay" tuner doing your tune you can probably boost to a good 200-250HP. With a good tuner you can push your stock motor to around 300HP as long as you upgrade your fuel system.
What kind of EMS/Fuel Management are you going to run? Crome, Uberdata, Hondata, AEM?
BTW- It's not the number of pounds of boost a motor can take, it's the amount of horsepower.
You may want to get a set of ARP headstuds. I just started having a head-lifting problem after about 6 months of only 7psi daily from a small turbo.
Old Dec 13, 2005 | 03:39 PM
Default Re: (Everyones Hero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Everyones Hero &raquo;</TD></TR><TR><TD CLASS="quote">With an "okay" tuner doing your tune you can probably boost to a good 200-250HP. With a good tuner you can push your stock motor to around 300HP as long as you upgrade your fuel system.
You may want to get a set of ARP headstuds. I just started having a head-lifting problem after about 6 months of only 7psi daily from a small turbo.</TD></TR></TABLE>
Ya, true. I've had a couple of my friends have to replace their headstuds and headgaskets.
Old Dec 13, 2005 | 09:05 PM
pcupo12's Avatar
Default Re: (808draggers)
A stock D series engine can handle 200whp. Some setups require 10PSI, others 6. It doesnt matter how many LBS of boost, 200whp is safe. Adding a thicker headgasket will lower your compression a tad, which isnt a bad idea. As for boost applications over 10psi you will need ARP headstuds, as the D series head lifts under boost. Theyre cheap. http://www.tunertoys.com
Old Dec 13, 2005 | 09:22 PM
JayDiem_k20_Dc5's Avatar
From: University of Massachusetts, Amherst, Ma, US of A
Default Re: (pcupo12)
CROME not Chrome as in Chrome Wheelz Yo
Stay under 8. You'll be blowing **** up. [
asergioc
30
Aug 10, 2007 11:50 AM
projectef
Jul 3, 2007 08:35 PM
drew338
Mar 20, 2007 01:01 PM
Topdawgg
Jan 23, 2006 06:54 PM
DubyaAye
Jun 7, 2003 03:07 AM
