90-93 DA integra fog light bulb question
do i have to take out the whole thing to change the bulbs? it doesnt look like there's any other way.
thanks for answering my stupid question, but its 13 degrees out and i dont feel like wasting time.
oh no no no no no...
all you do is take off that 8mm nut on the side of each foglight, then the whole foglight comes out.. on the back is a rubber garmet (sp), pull that off and inside is a clip that holds the bulb itself in place.. and a wire.
undo the clip and pull the bulb out, pull apart the connection between the wires, reverse the operation to re-install the bulb and fog light housing..
REMEMBER: that little clip compleats the circuit for that bulb to work, its the "ground" for the light... and that wire to the bulb is the positive power.. just make sure you have the bulb securely inplace, you'll see on the bulb housing that there is 2 notches that need to mate up with the fog light housing..
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. »</TD></TR><TR><TD CLASS="quote">oh no no no no no...
good luck</TD></TR></TABLE>
I hate everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudassVTEC »</TD></TR><TR><TD CLASS="quote">h3-55w</TD></TR></TABLE>
Yeah, i just bought a set in JDM yellow, but I already have the 1 piece headlight. I didn't know the housing was yellow, so the fog is probably going to be really yellow.
But yeah, its an H3 size.
i bought some hyper yellow F.lights for my da and the clip aint the same...the stock one is a round clip and the one i bought is kinda a flat one...how can i get this to fit??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuilttB18C5 »</TD></TR><TR><TD CLASS="quote">Yeah, i just bought a set in JDM yellow, but I already have the 1 piece headlight. I didn't know the housing was yellow, so the fog is probably going to be really yellow.
But yeah, its an H3 size.</TD></TR></TABLE>
yes they will but they will look kinda werid if the glare gaurds are in. i removed mine to get a full yellow look
