Lighting HID/Xenon kits, Retrofits and Associated Topics
singal light question
Old Jan 3, 2008 | 06:45 PM
DAJay93's Avatar
Default singal light question
i have a 93 integra and i wanna kno how i can make my signal lights light up like the DC's i have a pic for an example...
^^ see the bottom ones light up with the headlight? how can i make that happen 0_o
Old Jan 4, 2008 | 05:13 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You're talking about the turn signal lighting up bright?
If they are dual-filament bulbs, you can swap the power wires to the hi and low bulb filaments, but you will get hyper blinkers, won't be able to see your turn signals in the daytime or at night, and will most likely melt or deform the lens or housing.
Having the high filament on constantly like that will probably melt or deform the lens or housing, whether they are single or dual filament bulbs. I would highly recommend against doing that.
That picture could have been taken with the hazard flashers on, to give the appearance that they're on all the time.
Old Jan 7, 2008 | 03:17 PM
dr_latino999's Avatar
Default Re: (PatrickGSR94)
You could do the same things that the EF folks do, which is switch the socket for a brake light socket allowing you to use the low filament for the running lights and the high filament for turn signal / hazards.
sz9182
Oct 13, 2009 05:43 PM
pKjai
Oct 29, 2008 03:02 PM
shortlid
Nov 29, 2007 01:53 PM
civic89si666
14
Feb 22, 2006 05:46 PM
. M i c h a e l
Jan 5, 2006 03:23 PM
