for all the SOHC ZC pepole?????????????
Old Dec 12, 2005 | 02:59 PM
migizzel's Avatar
Default for all the SOHC ZC pepole?????????????
ok i would like to build my cyl head but im fairly new to this so i was wondering what would be the best cam other than the stock ZC to buy and also springs ,retainers and valves any ideas and or prices?
Old Dec 12, 2005 | 04:38 PM
kantfadedisazn's Avatar
Default Re: for all the SOHC ZC pepole????????????? (migizzel)
i hav this same swap in my crx if u want very good performance for low cost here are the mods witch i plan on doing, get a d16y8 intake manifold, its the type r manifold for sohc, then a exospeed sr909 cam costs $200 the specs are 294 degrees and 304 duration, nex a unorthodox racing crank pully, a prospeed ecu, get a header and an exhaust with 2.5 inch piping, a cam gear, all that should give u some really good hp, cuz the sohc zc is identical to the d16 a6 and that motor produced 113whp, and 113 torque, and the sohc zc has more power and torque, so ull deffinatley get some power from those mods hit me up if u want and i can tell u more about the parts hopefully that helps u out
Old Dec 12, 2005 | 08:43 PM
Default Re: for all the SOHC ZC pepole????????????? (kantfadedisazn)
not many people hav the jdm sohc zc
Old Dec 12, 2005 | 10:08 PM
turbodcivic510's Avatar
i rock the sohc zc,, makes GREAT power. best motor ive ever had
Old Dec 12, 2005 | 10:30 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kantfadedisazn &raquo;</TD></TR><TR><TD CLASS="quote">i hav this same swap in my crx if u want very good performance for low cost here are the mods witch i plan on doing, get a d16y8 intake manifold, its the type r manifold for sohc, then a exospeed sr909 cam costs $200 the specs are 294 degrees and 304 duration, nex a unorthodox racing crank pully, a prospeed ecu, get a header and an exhaust with 2.5 inch piping, a cam gear, all that should give u some really good hp, cuz the sohc zc is identical to the d16 a6 and that motor produced 113whp, and 113 torque, and the sohc zc has more power and torque, so ull deffinatley get some power from those mods hit me up if u want and i can tell u more about the parts hopefully that helps u out </TD></TR></TABLE> You'all are lucky I am up this late
- D16Y8 Intake Manifold, there is still a massive debate whether this makes more power over the D16Z6 manifold, just because it looks like the B18C5 IM doesn't mean it makes power like it. There are different things to take into account such as runner length/volumn and plenum diameter/volumn and where you want your powerband.
- Exospeed has been getting a lot of bad press lately, has the operation pulled itself back up and started shipping items in a timely fashion (As of late, no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Any Joe Blow &raquo;</TD></TR><TR><TD CLASS="quote"> I ordered from them ten million years ago, great customer service and prices</TD></TR></TABLE>
- DO NOT GET ANY AFTERMARKET CRANK PULLEY, you will kiss you bearings good bye, it may not be now, it may not be 6 weeks from now, they will go. Harmonic stabilization is used for a reason, not because Honda thought it would a fun thing to do.
- Instead of getting a generic ECU, chip your OBD-0 setup with Turboedit and have it tuned on a dyno if you wish WITH your setup in hand, not with what someone thinks will work best.
- Hmm....I have nothing on the exhaust, just add resonators for pete's sake, no need to **** off the neighbors and the local hornets by sounding like a nest of pissed off bees everywhere.
- A cam gear doesn't "add" power, it just finds it and moves it around.
- I like the contradiction where you say the SOHC ZC and the D16A6 are the same and then 20 odd words later (max, didn't count) you say the SOHC ZC makes more power and torque. This is where I would like to agree on the fact...that you are wrong. The only discernable difference between the SOHC ZC motor and the D16A6 is a slight variation of the exhaust lobe of the camshaft (correct me if I am wrong on that fact or know of anything else). The pistons, head, valves, all the same; maybe there was a change in the ECU but it wouldn't be major.
- D16A6 produced 113 / 113? You wouldn't happen to be talking of my currently deceased motor now would you?
https://honda-tech.com/zerothread?id=1306548
If so, I am honored
Old Dec 12, 2005 | 10:35 PM
1QuikSOHCZC's Avatar
Default Re: (g1_teg)
i got a sohc zc too..yea!! u guys have any pics of ur engine bays? i love my sohc, its a great motor, what do u guys run for fuel pressure? i wana give mine a lil more hp, do u kno how much of a difff that cam would make???
Old Dec 12, 2005 | 10:58 PM
RA61825's Avatar
bump, i also run a sohc zc vtec, best motor that single cam pulls i love it. WHat setup do you guys have with this motor.?
Old Dec 13, 2005 | 06:07 AM
c0nspire's Avatar
Default Re: for all the SOHC ZC pepole????????????? (RACERX72)
i have a zc vtec using a crower.
i dont wanna post my setup in this thread, its been posted in others but i will message it to you racer
My ZC
Old Dec 13, 2005 | 07:16 AM
ludesrv's Avatar
I have a SOHC ZC aswell in a 90 Civic Cx (STD for your yanks). I'm gonna start her up sometime this week. I'll get pics and vids. It's going turbo in spring .
Old Dec 13, 2005 | 09:44 AM
migizzel's Avatar
Default Re: (1QuikSOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1QuikSOHC &raquo;</TD></TR><TR><TD CLASS="quote">i got a sohc zc too..yea!! u guys have any pics of ur engine bays? i love my sohc, its a great motor, what do u guys run for fuel pressure? i wana give mine a lil more hp, do u kno how much of a difff that cam would make???</TD></TR></TABLE>
here is my engine bay it is not updated i have done more stuff to it since this pic
JDM SOHC ZC all the way
Old Dec 13, 2005 | 11:18 AM
Default Re: for all the SOHC ZC pepole????????????? (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> You'all are lucky I am up this late
If so, I am honored </TD></TR></TABLE>
wow that is some usefull info dr_latino999 thanks and yeah i was reffering to ur deceaced motor cuz it amazed me, so no after market crank pully huh i didnt know it would be that bad to put one on so should i sell mine
Old Dec 13, 2005 | 11:20 AM
Default Re: (migizzel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migizzel &raquo;</TD></TR><TR><TD CLASS="quote">
JDM SOHC ZC all the way </TD></TR></TABLE>
dam that is one clean ****
Old Dec 13, 2005 | 11:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kantfadedisazn &raquo;</TD></TR><TR><TD CLASS="quote">wow that is some usefull info dr_latino999 thanks and yeah i was reffering to ur deceaced motor cuz it amazed me, so no after market crank pully huh i didnt know it would be that bad to put one on so should i sell mine</TD></TR></TABLE> Aftermarket Crank Pullies in my experience (The cheap aluminum carved ones, not the actual balanced ones) are the devil. I purchased a Z6 that had one for about 9200 miles, ran the next 800 miles on a stock crank pulley and in that time a bearing spun..............I ragged the A6 to hell and back, no bearings went but I did lose a perfectly good piston and head in the process, ran the B2 to next month, lost piston rings due to age, yet a Z6 running an aluminum pulley {Clunk} The sound of my bearings commiting suicide.
Old Dec 13, 2005 | 01:40 PM
sohcef9's Avatar
Default Re: (kantfadedisazn)
im using the stage two crane cam.. feels nice... they say to use new stock valve springs but i didnt replace them.. im just waitin to do that when i get the head rebuilt and port and polished..
Old Dec 13, 2005 | 05:54 PM
migizzel's Avatar
Default Re: (sohcef9)
so if i use i crower cam i could buy stock springs and retainers with no problems?
how about valves? is ther anything better out there?
Old Dec 13, 2005 | 06:55 PM
c0nspire's Avatar
it depends on the cam, some allow you to use stock springs and retainers, others will say you need aftermarket. Their website should be able to tell you.
here are the crower cams for the d16. I have the FI Special
Old Dec 14, 2005 | 11:43 AM
sohcef9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c0nspire &raquo;</TD></TR><TR><TD CLASS="quote">it depends on the cam, some allow you to use stock springs and retainers, others will say you need aftermarket. Their website should be able to tell you.
Old Dec 29, 2005 | 06:24 PM
cvt's Avatar
cvt
Default Re: for all the SOHC ZC pepole????????????? (sohcef9)
I have a sohc zc in my 95 civic coupe, I'm running a Jackson racing supercharger on it 9lbs of boost, 310 cc injectors, 255 lph fuel pump, fmu, 4-2-1 header and a 2.25 thermo exhaust.
kixcrx
Feb 12, 2007 02:52 PM
racer-025
15
Jun 9, 2005 04:00 AM
91hondacrx
89
Mar 13, 2004 08:40 PM
Dwight Schrute
Feb 22, 2004 03:01 PM
crx88fast
17
Aug 7, 2003 04:53 PM
