obd1 injectors removed resistor box!!
Old Dec 12, 2005 | 01:34 PM
Six1oooEG's Avatar
Default obd1 injectors removed resistor box!!
i have a d15b7 in my 90 si hb i removed the resistor box and i wired up the 4red wires with the 1 yellow/blk wire, the car still wont start up, did i do something wrong? i eliminated the plug for the resistor box i cut b4 the green plug on the harness is that ok? or am i suppsoe to leave it connected and cut after the green plug? also i didnt sodder i just spliced and connected them together and black taped the connection. ive searched and found alot of good info i just hate wiring!
i went to rywire but i couldnt find the write up so im kinda lost in the dark.
funny thing is i drove my car with resistor box and obd1 injectors for awhile i hope i didnt damage the ecu or injectors the only prob i had was when the car sat for a few hours it wouldnt want to start it would just crank and cough and eventually turnover
im getting gas to the injectors btw i checked
Old Dec 12, 2005 | 04:08 PM
Six1oooEG's Avatar
Default Re: obd1 injectors removed resistor box!! (Six1oooEG)
cmon ppl someones gotta know wats going on did i do it right or wat?
Old Dec 12, 2005 | 04:13 PM
Pee Wee's Avatar
well i ghetto rigged mine. i just cut mine between the resistor box and plug and i have no problems.
Old Dec 12, 2005 | 04:39 PM
Six1oooEG's Avatar
i think i fried my injectors, i was running obd1 injectors w/resistor box for a good 3wks!!! i dam...
you think my ecu is also fried or just injectors? car was running yesterday sunday but the car wasnt 100 perscent it had a lil misfire after running for 5min a lil stutter when i gas itand was idleing rough
Old Dec 12, 2005 | 05:37 PM
Pee Wee's Avatar
well im no expert but i heard when you do what you did it fries the ecu but i could be wrong.
Old Dec 14, 2005 | 12:58 PM
Six1oooEG's Avatar
Default Re: obd1 injectors removed resistor box!! (EF8opey)
ne1 else know wat can happen
Old Dec 14, 2005 | 02:09 PM
west nile's Avatar
I would try new obd1 injectors, just go pull some from a junk yard and give them a good cleanin'.
Old Dec 14, 2005 | 02:42 PM
Pee Wee's Avatar
Default Re: obd1 injectors removed resistor box!! (west nile)
or borrow a working ecu from a buddy or your local pastor
Rasmusm
Apr 19, 2014 06:10 AM
apekd
13
Dec 30, 2008 10:47 AM
Homotor
Dec 14, 2007 12:29 PM
crawlin
Aug 17, 2006 06:52 PM
lilxvtecxpwr
Apr 12, 2004 05:36 AM
