going to adjust my valves... need advice
Old Dec 12, 2005 | 12:18 PM
idriveadelsol7's Avatar
Default going to adjust my valves... need advice
so i'm going to attempt a valve adjustment on a jdm d15b... any advice, things to look for? i'm armed with the snap-on tool and a feeler gauge but i'm not familiar with what is underneath the valve cover. i know what to do but i don't which is the intake or exhaust... where to start? i've searched the stickies...still confused as hell.
Old Dec 12, 2005 | 12:20 PM
ShadyBAB's Avatar
Default Re: going to adjust my valves... need advice (idriveadelsol7)
The easiest way to tell the difference between the intake and exhaust valves is the undeniable amount of oil and exhaust "muck" in the exhaust lobes.
Old Dec 12, 2005 | 12:24 PM
520_Motorsports's Avatar
Default Re: going to adjust my valves... need advice (ShadyBAB)
the exhauast valves are going to be the ones closest to you! The intake valves are on the back side (I/M is on the backside and the Exhaust is closer to you!) This is best done when the engine is cold. The feeler guage will go between the cam lobe and the retainer. any questions just pm.
Old Dec 12, 2005 | 12:34 PM
Default Re: going to adjust my valves... need advice (SlowAzEg)
cam lobe and retainer...
the teeth looking thingy on the cam right?
what does the retainer look like?
Old Dec 12, 2005 | 12:37 PM
Slopoke's Avatar
Here's a quick "how to" thread:
https://honda-tech.com/zerothread?id=1305086
I didnt read all the way thought that thread, but a few tips:
-Make sure your engine is cold
-The way they tell you to adjust valves in that article is: turn #1cly to tdc, adjust valves. Turn #3 cyl tdc, adjust valves. Turn #4 cyl to tdc, adjust valves. Turn #2 cyl to tdc adjust vaves.
But there is an easier way!
Turn #1 cyl to TDC. You can adjust all the valves on cyl #1. You can also adjust the intake valves on #2 and the exhaust valves on #3.
Now turn the crank 360 degrees and put #4 cyl at TDC. You can adjust all the valves on #4. You can also adjust the intake valves on #3 and the exhaust valves on #2.
Then your done.
*edit
Also, if you're standing in front of the car, looking down at the motor. The cylinder numbers are from left to right: 4 3 2 1
Old Dec 12, 2005 | 12:40 PM
Soccerking3000's Avatar
its on top of the spring it looks like a disk and in the center there is a hole where the valvestem goes through, right above it is the rockerarm you measure the distance between the rockerarm and the retainer center. I think you should have a shop do this by your previous posts, you dont understand well enough and could mess things up pretty bad...
Old Dec 12, 2005 | 01:00 PM
Default Re: going to adjust my valves... need advice (Soccerking3000)
I agree if you don't have enough mechanical experience you should not attempt this on your own. you could over compensate in either direction and either cause coil binding or go to loose and loose a keeper and end up having to rebuild an engine because you drop a valve.
Old Dec 12, 2005 | 01:56 PM
i seen it done on a b series... looks totally different that's why. lol well, i'm going to do it. i just need to figure out where everything is at.
Old Dec 12, 2005 | 02:43 PM
nub's Avatar
nub
if you cant pop the valve cover and tell what is what then leave it alone
Old Dec 12, 2005 | 02:45 PM
ShadyBAB's Avatar
Default Re: going to adjust my valves... need advice (nub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub &raquo;</TD></TR><TR><TD CLASS="quote">if you cant pop the valve cover and tell what is what then leave it alone</TD></TR></TABLE>
Word. Get some Pro help man, you might being doing more bad than good attempting this on your own
Old Dec 12, 2005 | 03:16 PM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 &raquo;</TD></TR><TR><TD CLASS="quote">i seen it done on a b series... looks totally different that's why. lol well, i'm going to do it. i just need to figure out where everything is at.</TD></TR></TABLE>
You can do it. Just take your time.
Did you read through the link I posted? That will answer some of your questions.
Old Dec 12, 2005 | 03:26 PM
Default Re: going to adjust my valves... need advice (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke &raquo;</TD></TR><TR><TD CLASS="quote">
Did you read through the link I posted? That will answer some of your questions.</TD></TR></TABLE>
thanks... i've been reading that thing for a couple of days now. i'm going to actually look a good look under my cover this weekend. the concept is pretty simple, it's just finding everything for the first time. we all need to start somewhere.
Old Dec 12, 2005 | 03:53 PM
Slopoke's Avatar
You can IM me if you have any questions.
thegatekeeper14
Dec 27, 2010 09:40 AM
mejim707
May 15, 2009 09:52 PM
tmmyby83120
Mar 15, 2007 09:01 AM
1 2 NV
15
Aug 16, 2006 04:40 PM
vwandhondaboy
Sep 29, 2002 12:08 PM
