where's the automatics flex plate?
here is a generic definition i found on the net for ya:
The flywheel, or flexplate, mounts to the engine's crankshaft and also serves as a mounting location for the torque converter. Consequently, the flywheel or flexplate transmits engine torque to the torque converter housing. The flywheel?s ring gear also serves as an engagement point for the pinion of the starter motor when cranking the engine. Because of the lightweight design of the flywheel or flexplate, it does not help to smooth out power pulses from the engine like the flywheel does on a car with a manual transmission. On cars with automatic transmissions, the torque converter provides this function.
peace
eric
peace
eric
madswapper
May 1, 2005 05:01 PM
