BLOX everyday BLOWOUT PRICES!!
we will not be undersold on any BLOX products!
BLOX high performance intake manifold
The Blox one-piece cast aluminum intake manifold will improve your engine's overall flow characteristics compared to the factory unit. Using the latest in casting technology reduces its overall weight and makes the Blox manifold the lightest in the industry. Each application has been designed using a larger plenum and longer intake runners, then tuned for peak power at high RPM. Blox intake manifolds are ideal for forced induction applications. All factory sensors and throttle body are utilized, while recessed bolt holes make for a simple installation.
available applications
B16, B18 a/b/c(LS and GSR)
Pm for lowest price ever!
BLOX B-series camshafts
BLOX high performance camshafts offer the enthusiast increased horsepower and torque over the entire RPM range, through various designs and custom profiles.
All camshafts start off as raw castings sourced from OEM materials. Each is then manufactured using the latest design software and chill-casting technologies. All camshafts are CNC-ground to precise and exacting tolerances and specifications.
BLOX currently offers different levels of performance through its Tuner and Competition Series. Custom (semi-blank) camshaft cores are also available for racers and engine builders that require blank cores in order to grind to their own profiles.
D-series STG1 and STG2 - PM for lowest price!
B-series STG1, STG2, Turbo, and HSL PM for lowest price!
BLOX turbo manifold
The BLOX turbo exhaust manifold is constructed from high silicone ductile iron, using the latest casting technologies. Each cast exhaust manifold features a centralized wastegate bung between the #2 and #3 cylinders, to greatly improve the boost response, and mates to T3/T4 turbocharger.
Also, the 3.5mm thick intake runners dramatically reduce the overall weight of the manifold, making the BLOX manifold superior over its competitors.
BLOX turbo exhaust manifolds come with a lifetime warranty against cracks and are available for Honda B-series engines.
PM for lowest price possible!!
Toll Free order line: 1-877-23-TURBO
prostreetonline
Nov 26, 2008 07:08 AM
prostreetonline
Dec 29, 2004 06:43 PM
