4g m2b4 speed calculator
gear ratio tire diameter
1 3.307 w 215
2 1.95 a/r 0.45 96.75
3 1.36 I/d 17 431.8 528.55 20.82487 10.412435
4 1.071
5 0.787
final drive 4.266
mph = rpm x tire radius / final drive x 168
rpm 7500
final gear ratio 14.107662 8.3187 5.80176 4.568886 3.357342
mph 32.94953113
55.87902535
80.12066135
101.7405224
138.4550183
I found this website withv teh quy posting this speed per each gear calculator. http://www.forums.maxima.org/p...70049
i adopted it to a m2b4 transmission with one of my sets of tires. my question is, what is the 168 that he's using in his calculator. i copied and pated my excel cells into here so you can't see all the calculation, but does it look right? I've heard people saying they've been up to 140+ in their 4g's so this make sme really skeptical unless they got on 20" rims
and on teh maxima site thing, the guy says his tire radius is 12.75" can that be right? he's rolling on 25.5" of tire?
1 3.307 w 215
4 1.071
5 0.787
final drive 4.266
rpm 7500
mph 32.94953113
55.87902535
80.12066135
101.7405224
138.4550183
here
http://www.car-videos.net/tool...ulate
153mph at redline
or 167 at 8200 sum people take it that high
thats with a 205/55/r15
I think that this is off a bit because I remeber 177mph the top speed at 8200/8100. used to be on h22a.org. A guy ran his car on the dyno.
and I remeber using a different calculator at one time and getting 176.something
also I know I will get flamed for speeding but just chill.
Vtec hits at I believe 105mph in my car. so this calculator might be a tad off.
Modified by kulrevon at 3:10 PM 12/12/2005
153mph at redline
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutta »</TD></TR><TR><TD CLASS="quote">does anyone here read sport compact car? there was a technobabble a while ago about figuring this out. maybe someone could scan it or summarize it?</TD></TR></TABLE>
or maybe someone coudl figure out which issue it was and let me know?.. it's pissing me off not knowing if this is right or not.
I found this site from an old post: http://www.turnzero.com/techni...lator
Results with 205/55/15 tires, 8200 max rpm, and gear ratios you listed:
First Gear
Total gearing in first gear: 14.107662
Maximum speed in first gear: 41.3 mph
2nd gear
Total gearing in second gear: 8.3187
Maximum speed in second gear: 70 mph
3rd gear
Total gearing in third gear: 5.80176
Maximum speed in third gear: 100.4 mph
4th gear
Total gearing in fourth gear: 4.568886
Maximum speed in fourth gear: 127.5 mph
5th gear
Total gearing in fifth gear: 3.357342
Maximum speed in fifth gear: 173.5 mph (AKA hauling serious *** in a Prelude)
And the finishing touch...the handy dandy graph...
First Gear
2nd gear
3rd gear
4th gear
5th gear
Honda318dx
51
May 27, 2005 09:59 AM
Casey
Aug 20, 2003 01:33 AM
calculator, gear, gearing, honda, hondamarketplacecom, m2b4, mph, mphrpm, ratio, ratios, series, speed, speeds, topspeed, transmission
