zc boggs out really bad needing help
Old Dec 12, 2005 | 09:50 AM
zccr-xsi's Avatar
Default zc boggs out really bad needing help
ok guy i got a prob. when i changed my timing belt and then started the car it ran fine but had a code 9.so i take the timing belt off the cam pulleys line up the cams put it back on now when i start it it seems too idle fine,but when i give it gas it boggs out really bad.the only code it is showing is code 20 which it had that before i changed the timing belt and it ran fine.any ideals what this could be from?btw i know i lined up the crank sensor cause when i started it for the first time after i put the belt on it ran and reved ok.but as soon as i reline the cam gears it starts acting funny.
Old Dec 12, 2005 | 09:55 AM
NACvicSi's Avatar
Default Re: zc boggs out really bad needing help (vteckillenzc)
Reset your dizzy timing?
Old Dec 12, 2005 | 09:57 AM
zccr-xsi's Avatar
ight ill try it!
Old Dec 12, 2005 | 10:10 AM
zccr-xsi's Avatar
Default Re: zc boggs out really bad needing help (NACvicSi)
didnt work.seems once it swarmed up it does it?when i hit the gas it bogg really bad then shuts off?any more ideals
Old Dec 12, 2005 | 10:49 AM
Kapolei INTEGRA's Avatar
well i had an experience like that once. right after a timing belt change, we were about gear teeth off on the cam gears and that made the car bog, but idled fine. after readjusting it was good again. so you should consider checking ur crank gear position as well as the cam gear position. hope u fix the problem
Old Dec 12, 2005 | 11:29 AM
zccr-xsi's Avatar
Default Re: zc boggs out really bad needing help (Kapolei INTEGRA)
i know the crank sensor is right.im relining up the cam gears now.ill post later let u know if it was fixed.
Old Dec 12, 2005 | 01:25 PM
zccr-xsi's Avatar
come-on where are all the honda gurus at?
Old Dec 12, 2005 | 04:20 PM
zccr-xsi's Avatar
know one knows how to fix this?
trav_89_crx_b7
Sep 26, 2011 02:54 PM
pkdog167
Nov 10, 2009 10:29 PM
JCCOOL43
Nov 7, 2006 05:32 PM
Voodooboy520
Jun 3, 2006 07:34 AM
lilxvtecxpwr
Dec 25, 2002 12:21 AM
