d16y7 tranny with d16z6 motor
Old Dec 12, 2005 | 07:35 AM
ckrieg's Avatar
Default d16y7 tranny with d16z6 motor
The input shaft baring on my z6 tranny is going, and this guy has a y7 tranny he wants to sell me for about $100US. Now, I've read that the y7 tranny is really shitty gear ratios and will actually slow my car down...how much truth is there to this? Any other disadvantages? As far as I know, all D series parts will bolt up to each other just like b series ones will. Is that right?
Old Dec 12, 2005 | 07:44 AM
eg6ajk's Avatar
Default Re: d16y7 tranny with d16z6 motor (ckrieg)
yes, indeed ratios on the y7 tranny are pretty crappy along with even crappier FD. Needlesly to say, even at redline shifts you will fall out of vtec range.
yes 92-00 d-series trannies and blocks are interchangle some differences in mounting and overall look but defintaly will work.
Old Dec 12, 2005 | 07:47 AM
Ricey McRicerton's Avatar
Default Re: d16y7 tranny with d16z6 motor (eg6ajk)
I'd rather stop driving the car then go back to a y7 tranny. The gears are horribly long and make the car much slower than it should be.
Honestly, you're going to hate driving with the Y7. It's ungodly long.
Old Dec 12, 2005 | 08:02 AM
Jizzmaster Zero's Avatar
(banned)
Default Re: d16y7 tranny with d16z6 motor (Ricey McRicerton)
Your input shaft bearing is located in the center of your flywheel, not the transmission. And even if it is bad, spend a few bucks for a new one and reuse your better z6 tranny, it'll be the same amount of work either way.
Old Dec 12, 2005 | 09:58 AM
ckrieg's Avatar
Default Re: d16y7 tranny with d16z6 motor (Jizzmaster Zero)
hmm..well, I got some quotes for fixing it, as I'm not THAT mechanically inclined...and to pull the tranny, fix it, and put it back in, would be around $1000....
Old Dec 12, 2005 | 10:24 AM
eg6ajk's Avatar
why not just call you wrecking yards or JDM importers and get a 92-5 Si/D15b sohc vtec tranny or 96-00 1.6el or Si tranny. they are anywhere from $150-450
http://car-part.com/cgi-bin/search.cgi
Old Dec 12, 2005 | 10:45 AM
kyden's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jizzmaster Zero &raquo;</TD></TR><TR><TD CLASS="quote">Your input shaft bearing is located in the center of your flywheel, not the transmission. And even if it is bad, spend a few bucks for a new one and reuse your better z6 tranny, it'll be the same amount of work either way.</TD></TR></TABLE>
no, that would be the pilot bearing. input shaft bearing is on the other end of the input shaft.
Old Dec 12, 2005 | 11:07 AM
snatch's Avatar
Default Re: d16y7 tranny with d16z6 motor (kyden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyden &raquo;</TD></TR><TR><TD CLASS="quote">
no, that would be the pilot bearing. input shaft bearing is on the other end of the input shaft.</TD></TR></TABLE>
Right-o. That's the pilot bearing in the flywheel. Input shaft bearing is on the input shaft just on the other side of the clutch housing for the tranny.
Old Dec 12, 2005 | 01:15 PM
ckrieg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk &raquo;</TD></TR><TR><TD CLASS="quote">why not just call you wrecking yards or JDM importers and get a 92-5 Si/D15b sohc vtec tranny or 96-00 1.6el or Si tranny. they are anywhere from $150-450
http://car-part.com/cgi-bin/search.cgi</TD></TR></TABLE>
I'll check the local wreckers....but I'm located in canada, and customs and shipping on a tranny from the US would be pretty hefty. But a d15b would have similar ratios to the z6?
Old Dec 12, 2005 | 01:37 PM
97civicdx's Avatar
The y7 tranny isnt as long legged as the 70 hp CX hatch tranny. That will get you 80 mph at 2500 rpm. hehe. Once it gets there.............
Old Dec 12, 2005 | 03:24 PM
lowgman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ckrieg &raquo;</TD></TR><TR><TD CLASS="quote">
I'll check the local wreckers....but I'm located in canada, and customs and shipping on a tranny from the US would be pretty hefty. But a d15b would have similar ratios to the z6?</TD></TR></TABLE>
I will be swapping out my y7 tranny with a y8 tranny that I picked up a while ago in the next month or so (maybe after new years). PM me if you are interested.
I am located in Richmond, BC.
Raocorp
15
May 20, 2009 09:14 AM
88 EF Hatch
Transmission & Drivetrain
Apr 24, 2009 11:28 PM
88 EF Hatch
Apr 20, 2009 11:34 PM
puertoroc7976
12
Oct 8, 2006 03:00 PM
