Big Brake Question?
Old Dec 12, 2005 | 07:00 AM
vtecgod's Avatar
Default Big Brake Question?
i have a question need some help guys bought a bear big brake kit used with brand new pads it's been on the car for a little while now but it's pulsating pretty bad when stopping from like 60mph and up. My question is can i turned these rotors or do i need to buy some new ones? thanks.
Old Dec 12, 2005 | 07:45 AM
jdmcars.com's Avatar
Default Re: Big Brake Question? (vtecgod)
Most of the time, the manufactor of the brakes of either a cross drilled or slotted (whichever your kit may have) would recommend NOT turning the rotors.
IMO, if you spent the money on a brake upgrade -you should respect your orginal thought of your needing more brake power -contact the company of the brake kit, find out what rotor they used and get some new ones.
Many times, if you find out the spec of the rotor, you can find the rotors cheaper. I have seen kits use simple stock size performance rotors of a VW Corrado G60. In that case, the brake kit company wanted to sell the rotors for about $250 each, but I found them from Brembo for $80 each.
Old Dec 12, 2005 | 08:28 AM
mrbigg9032's Avatar
the baer brake kit uses a 12.7 or 13 inch rotor the corrado uses like 11 inch rotors. Your best bet is to call up baer and see what they say about getting new rotors.
Old Dec 12, 2005 | 11:05 AM
vtecgod's Avatar
Default Re: Big Brake Question? (jdmcars.com)
Thanks for the info man i will check into it i didn't think with the rotor being slotted and drilled that you could turn them. the rotor is 13''. how much do they usually run about?
pcguy760
Suspension & Brakes
Sep 11, 2011 01:23 PM
kwah
Suspension & Brakes
Jan 17, 2011 08:18 AM
clin20
Jun 7, 2004 08:30 AM
blueturboteg
Dec 3, 2003 03:27 PM
