check engine light!!!!!!!!
Old Dec 11, 2005 | 09:17 PM
leftcoast's Avatar
Default check engine light!!!!!!!!
does anyone know how to check the check engine light on a obd1 p28. i heard there is a cheap trick to making it flash for you. anyone know what it is?
Old Dec 11, 2005 | 09:38 PM
PrinceAli132's Avatar
Default Re: check engine light!!!!!!!! (leftcoastdrifter)
Some general stuff like this, try looking through the FAQ at the top. Thats where i got this from; https://honda-tech.com/zerothread?id=978933
Or http://www.team-integra.net/se...ID=34
Ali
Old Dec 11, 2005 | 10:33 PM
watsvtecEK's Avatar
Turn you car on the ON position without starting it, it should light for a few seconds.
Old Dec 11, 2005 | 10:48 PM
jBj's Avatar
jBj
Yea follow the pics of the T-I site, but follow the codes off the H-T site, some of those codes on team-integra are wrong...
Once you jump that plug, turn your key to the ON position, you CEL will flash and give you the code, but dont worry about getting it the first time, it will repeat the series of flashes over and over.
Old Dec 12, 2005 | 07:35 AM
SSBPGSR's Avatar
Default Re: check engine light!!!!!!!! (jBj)
long flash = 10
short flash = 1
so..one long flash+5 short flashes= code 15.
then go here and see what CEL your throwing
https://honda-tech.com/zerothread?id=1171263
good luck
speed_demon018
Mar 12, 2010 06:47 AM
NewEra
Jul 20, 2009 08:13 PM
90dteg
Sep 18, 2008 12:54 PM
iluvmyEJ1
May 20, 2007 06:01 PM
lowered94accord
Mar 16, 2007 08:27 AM
