is this worth it?
Old Dec 11, 2005 | 08:44 PM
rexless_wreck's Avatar
Default is this worth it?
can you give me your opinion if id be getting owned on this deal or if its a pretty good deal for 3500$$
1988 CRX DX
JDM B16 engine swap from hmo w/ lsd trans
Wiring from rywire
obd0 w/ pr3 ecu
Haport mounts/shift linkage
Excedy Stage 1 Clutch
No a/c
Stock Exhaust
Short Ram Intake
Hondata IM Gasket
Test Pipe
Short Shifter
Short Shifter Bushings
New Alternator
Brakes:
15/16" MC
New Brake Booster
Goodridge stainless lines
Brembo front drilled/slotted rotors
Axxis Pads
Remanu. Calipers
New hard lines for rear drums
New rear drum pads
Suspension:
Avid Racing Traction Bar
Interior:
Hunsaker Seats
JDM Shift boot y0 (red stitching)
New Black carpet
Pioneer 4 Way speakers installed in car, does not come with a cd player, can come with jvc radio, but the cd part does not work.
When swapped, new rotor/dist. cap, ngk plug wires, bosch +2 plugs.
Always used royal purple oil, 5.99/quart.
Already changed mtf 2 times, used honda MTF each time.
The bad:
Needs fender (drivers side) a little bent up, and maybe a hood, hood is questionable for repairs
Old Dec 11, 2005 | 08:47 PM
crxnj's Avatar
Default Re: is this worth it? (rexless_wreck)
ANY Rust??
Old Dec 11, 2005 | 08:51 PM
no i dont think so body looks in excellent condition
Old Dec 11, 2005 | 09:27 PM
crxnj's Avatar
Default Re: (rexless_wreck)
Sounds like a good deal then..
Old Dec 11, 2005 | 11:06 PM
burnt_rice's Avatar
that's a pretty good deal consididering the re-wiring for the motor and the extensive amount of time a work put into it if it came out clean......just buy it....
Old Dec 12, 2005 | 03:22 AM
VegaS10's Avatar
If the car is in VA, that's a damn good deal...
Old Dec 12, 2005 | 05:36 AM
i just found this and im thinking this is a better deal for 3600$$
1988 CRX HF WITH ALL SI PARTS
car is fast and runs strong
SUSPENSION:
lightest model crx
1991 Crx Si Full suspension
rear disc setup
neuspeed lower rear tie bar and upper strut bar
kyb struts
skunk2 springs
EXTERIOR:
car needs paint
black hx rims (11.7 lbs)
falken azenis
amber bumper and corner lights
Nokya Artic Blue Headlight Bulbs (highs/lows)
ENGINE:
jdm b16a
itr valve cover
raw carbon fiber spark plug cover
ctr crank pulley
j1 tranny
good axles
skunk2 intake manifold
cold air intake
hasport b series billet mounts
pr3 ecu vtec 4800 no speed limiter
b series shift linkage
RS*R exmag catback
magnaflow 2.5inch cat
vafc2 not installed
INTERIOR:
alarm with power locks
*MINT* 88 Si Seats NO RIPS
immaculate Interior
jdm amber clock
SiR Rear Seat
SiR Rear Cargo cover
88 Si door panels
Grant Steering Wheel
gsr cluster install
Old Dec 12, 2005 | 06:29 AM
CRX Toad's Avatar
Need pics
Old Dec 20, 2005 | 08:02 PM
burnt_rice's Avatar
yeah an hf is a better choice but only because the dx could have been wired incorrectly which could lead to alot of bullshit problems.....plus the hf is lighter so i would go with that but ask for pics and post them up and i'd could give you my critism..good luck
ilovemyh22
May 13, 2010 05:52 PM
Deadly Se7en
Oct 25, 2009 11:47 AM
TRQLESS
Dec 17, 2005 09:39 AM
TRQLESS
Nov 12, 2005 05:01 PM
dohcdelsol
Sep 1, 2003 05:30 PM
