HELP__ car idols high after head build HELP!!!
heres my deal i just put on a fully built b16 head on my gsr bottom end. I put in stage 2 skunk2 cams and 310 injectors! im thinking that hondata (im running s200) is thinkin the 240 injectors are in there still and the 240 were maxed out b/c i WAS runnin 12:5:1 compression. would 310's maxd out cause my car to idol around 2,600-3,000??? ive checked all the hoses HELP!!!! please... any comments or bumps are appericated
check the cold idle valve on the back of the head just under the TB. should have 2 screws holding the cover plate on... take that off and screw the bolt clockwise so its going in.
if that doesnt work, it's probably your hondata. did you have a new map burned after you put the 310s and everything back together? if the burned map still thinks it has the duty cycle and flow of the 240s, then it'll throw it off with the 310s in there and not adjusted for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 Spec R »</TD></TR><TR><TD CLASS="quote">What are your IAT temps at? Intake valves hanging open or slightly bent intake valves can also cause a high idle.</TD></TR></TABLE>
We didn't check this last nite but hes getting tuned today so he should be able to post up an answer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjeff »</TD></TR><TR><TD CLASS="quote">FOUND IT!!! wrong throttlebody gasket
its always the simple stuff...
</TD></TR></TABLE>its always the simple stuff...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjeff »</TD></TR><TR><TD CLASS="quote">FOUND IT!!! wrong throttlebody gasket </TD></TR></TABLE>
hows it runnin now?
hows it runnin now?
MARVNVRAM
Engine Management and Tuning
Apr 24, 2009 02:46 PM
jdmjeff
Dec 11, 2005 07:52 PM
