___car revs really high after motor build??? HELP ASAP___
heres my deal i just put on a fully built b16 head on my gsr bottom end. I put in stage 2 skunk2 cams and 310 injectors! im thinking that hondata (im running s200) is thinkin the 240 injectors are in there still and the 240 were maxed out b/c i WAS runnin 12:5:1 compression. would 310's maxd out cause my car to idol around 2,600-3,000??? ive checked all the hoses HELP!!!! please... any comments or bumps are appericated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjeff »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
check for faulty intake manifold gasket, and make sure the old one came off completely.
On one of my cars it was idleing at 3000 because of the map sensor and TPS, and unplug the hondata to see if it still does it
Modified by JDMdc2lsVtec at 8:51 PM 12/11/2005
Dude, even a vacuum leak wouldn't cause an idle that high. I'd say its a software issue or a HORRIBLY out of adjsutment idle screw.
ive checked everything yall have stated other than the hondata! but i did undo my battery! i dont know what to do!!!
mike1114
Apr 17, 2006 05:24 PM
Kwuaymaikrup
Aug 5, 2003 10:05 PM
