got a ? about ls/vtec swap
Old Dec 11, 2005 | 06:18 PM
97turboteg's Avatar
Default got a ? about ls/vtec swap
i want to get a vtec head, such as gsr or type r, for my non vtec b18b1. if i bought a gsr head, could i just swap them, or is there more work involved? will everything bolt right up??? i need car help! any ideas?
Old Dec 11, 2005 | 06:29 PM
DC4cedInducted's Avatar
Default Re: got a ? about ls/vtec swap (97turboteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97turboteg &raquo;</TD></TR><TR><TD CLASS="quote">i want to get a vtec head, such as gsr or type r, for my non vtec b18b1. if i bought a gsr head, could i just swap them, or is there more work involved? will everything bolt right up??? i need car help! any ideas?</TD></TR></TABLE>
it would be better if you searched for it..its not a complicated process..but it does involve a few items,before you can do the ls vtec swap.
Old Dec 11, 2005 | 06:32 PM
Elbowpunk's Avatar
Default Re: got a ? about ls/vtec swap (DC4cedInducted)
V-tec head, cams, bolts, ecu, spark plugs, intake manifold, distributor,
^^ All on the Vtec side
Old Dec 11, 2005 | 07:37 PM
stockep's Avatar
Default Re: got a ? about ls/vtec swap (Elbowpunk)
u also need to tap the head to run the oil line for the vtec golden eagle has a kit u can buy. that would be the best bet to buy the kit. it has the oil line the sandwich in which goes between the oil filter and the fitting u need to tap the head with runs a bout 120.
Old Dec 11, 2005 | 08:26 PM
blackdelslo's Avatar
Default Re: got a ? about ls/vtec swap (stockep)
oh yeah and once u put your vtec head on there, dont expect to rev out to 8grand on a stock ls bottem end, it was never made to do that.
Old Dec 11, 2005 | 08:45 PM
psegs80's Avatar
Default Re: got a ? about ls/vtec swap (delLudeVTEC)
The cheapest way to to rev it to or past 8000rpms, is p30 or pr3 pistons ( out of a b16a ) and get arp rodbolts for your stock Ls rods!! You will also probably need new oem rod bearings! ( low comp high revs is bad so the b16a pistons will bring comp up and the ARP rod bolts will make sure you don't spin a bearing)
Old Dec 11, 2005 | 08:57 PM
reccommendations :
1. Get the Golden Eagle LS vtec conversion system,that comes with everything you need.
2.Get some Eagle forged Rods
3. get some forged pistons,for your turbo setup
4. get some arp rod bolts,and arp head studs
5. get a GSR timing belt,ITR water pump,and ITR oil pump
6.get an ecu,that will support Vtec (P72,P28,etc)
i could keep going on..but researching the rest of the way will be enough.
Old Dec 12, 2005 | 06:04 AM
Elbowpunk's Avatar
"1. Get the Golden Eagle LS vtec conversion system,that comes with everything you need."
^^ WHere can you get that at?? like off internet or what ?
Old Dec 12, 2005 | 07:34 AM
98IntegraLSNonVtec's Avatar
Default Re: (Elbowpunk)
yeah like off the internet search "golden eagle vtec conversion" on google
Old Dec 12, 2005 | 07:37 AM
ecks_fourttwo's Avatar
Default Re: (98IntegraLSNonVtec)
ive got a p72 ecu for sale if you need it....lmk
Old Dec 12, 2005 | 07:40 AM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elbowpunk &raquo;</TD></TR><TR><TD CLASS="quote">"1. Get the Golden Eagle LS vtec conversion system,that comes with everything you need."
^^ WHere can you get that at?? like off internet or what ?</TD></TR></TABLE>
http://www.lightningmotorsports.com/ge_engine.htm
lostinaworldsocold
Jan 25, 2020 07:56 AM
CiViCBruh
Apr 3, 2008 03:55 PM
Dj Skidz7
Mar 3, 2006 02:49 AM
98IntegraLSNonVtec
60
Feb 28, 2006 04:46 PM
JDM_Risa
Mar 16, 2003 01:42 PM
