no vtec n can't calibrate tps correctly!!!!
Old Dec 11, 2005 | 05:38 PM
akteamster's Avatar
Default no vtec n can't calibrate tps correctly!!!!
97 Jdm b18c
In 96 ek ....I haven't had vtec since swap was completed. I used an ex harness to avoid having to run extra vtec wires. The only codes the motor is throwing is code 1 for o2 sensor and code 7 for tps which lead me to swap the tps wit one from a gsr I found. I was trying to calibrate it but I can only get it to .42 at closed throttle, not to .45 as it should be. At wot it only reads 1.8 instead of 4.5 like it should. What can be causing this????? I linked my vtec problem to the bad tps becuase oil level is good, solenoid is good, and the wiring was done correctly during the swap, and I was told by several people including ht members that it could be the cause of no vtec. Now that I put in a working sensor and I can't seem to get the right voltage readings nor clear the cel code leads me to believe I have a bigger problem. Any input is appreciated, I am going crazy trying to get the car running right.
Old Dec 11, 2005 | 06:16 PM
akteamster's Avatar
Default Re: no vtec n can't calibrate tps correctly!!!! (akteamster)
Bump for some answers please
Old Dec 11, 2005 | 06:23 PM
akteamster's Avatar
Bump for answers
Old Dec 11, 2005 | 06:54 PM
Slopoke's Avatar
Are you getting the proper 5volt to the tps?
If so, then you either have a bad tps sensor, or its not mounted properly.
.5v closed and 4.5 open. just fyi.
Old Dec 11, 2005 | 10:50 PM
akteamster's Avatar
Default Re: no vtec n can't calibrate tps correctly!!!! (Slopoke)
yes im pretty sure its mounted correctly....helms says .45 at closed throttle
Modified by akteamster at 12:25 AM 12/12/2005
Old Dec 12, 2005 | 07:13 AM
Slopoke's Avatar
According to Alldata(if your using your stock '96 civic harness), you should have a yel/blu(reference voltage(constant 5v)), red/blk(sensor input), and grn/blk(sensor ground).
Have you checked the yel/blu wire to make sure your getting 5volts there?
If you are, but you are only getting 1.8 at WOT(at the red/blk), then your sensor is bad or you have it mounted incorrectly.
Old Dec 12, 2005 | 08:57 AM
akteamster's Avatar
i will test the yellow blue wire to see if it is gettin a constant 5 volts.
FASTESTCB7inQNZ
Nov 18, 2009 06:41 AM
akteamster
Dec 2, 2005 09:19 AM
akteamster
Dec 1, 2005 07:01 PM
jonas
Mar 15, 2003 03:09 PM
89sir-9
Jun 18, 2002 11:02 AM
