OT What tire size are you running on JDM 16's
trying to figure out what tire size to get on my new rims. they are the jdm 16's btw my car is real low, what size to u think would work best as far as rubbing issues
205-45-16
215-40-16
215-45-16
205-45-16
215-40-16
215-45-16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo »</TD></TR><TR><TD CLASS="quote">curious what kind brand and type of tire are you running (machgo5go)</TD></TR></TABLE>
Just cheap Kumho ECSTA Supra 712. Came with it when I bought the package used.
I am thinking next summer go back to JDM Oem size of 215-45-16 from Dunlop Direzza DZ101.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machgo5go »</TD></TR><TR><TD CLASS="quote">
I am thinking next summer go back to JDM Oem size of 215-45-16 from Dunlop Direzza DZ101.</TD></TR></TABLE>
try the new hankooks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs »</TD></TR><TR><TD CLASS="quote">As far as rubbing issues...205-45-16
However, 215-45-16 is the right size.</TD></TR></TABLE>
I dont have rubbing issue (205-40-16)...
205/50/16
Rims came off the boat with these tires.........I'll probably be changing them to a lower profile next year since one tire blew and you can't buy RE-01 replacements here.
No rubbing issues.....
215/45/16" Yoko ES100 (JDM version) with F:6mm R:4mm spacer (front to clear Spoon Calipers) rear just for more even look. No rubbing or issues.
205/45/16 for me as well on Yoko ES-100s with no rubbing issue on stock height.
Oh by the way lastlude2k1se, are those spoon wheel lugs you got on? If they are can you recommend a place in edmonton or calgary which sells them?
Modified by DelSoln at 2:12 AM 12/13/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type AAARGH »</TD></TR><TR><TD CLASS="quote">What red lugnuts are you using?</TD></TR></TABLE>
They were the spoon lugs......that was just temporary, if you notice in the first pic I am using the OEM lugs.
The best match is either 205/45-16 or 215/45-16. Here is how the outer diameters of the various sizes mentioned in this topic compare with USM stock:
195/55-15 (stock)
205/45-16 -0.8 percent
215/45-16 +0.7 percent
215/40-16 -2.9 percent
205/40-16 -4.2 percent
205/50-16 +2.7 percent
225/45-16 +2.3 percent
From these numbers, you can see why those two sizes are a better fit than the others.
In choosing between those two, it may depend on which tire you want to use; there are more tires available in 205/45 than 215/45.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by py »</TD></TR><TR><TD CLASS="quote">I dont have rubbing issue (205-40-16)...</TD></TR></TABLE>
You're never going to have a rubbing issue when you use a tire size that is much too small.
But there are other reasons for choosing the 205/45 or 215/45 rather than the undersized 205/40, which is a good size for many older Civics.
195/55-15 (stock)
