PLEASE HELP bought a 91 crx today and it has some engine problems
Old Dec 11, 2005 | 04:59 PM
92civeg's Avatar
Default PLEASE HELP bought a 91 crx today and it has some engine problems
ok just sold my 2004 wrx today and bought a 1991 honda crx si....
the car was traded into a local dealership with a burnt valve.
one of the mechanics at the dealership bought the car and "repaired it" and then sold it to me...here is what he said he did to the car
headgasket
valves
t-belt
waterpump
cap,rotor,plugs,wires
the car has 201401 miles and is in decent cosmetic shape but the car has NO POWER AT ALL it seems like it wants to pull but it wont.
i did a compression check today and its 185 on all 4 cylinders i set the ignition timing to stock setting and it still has no power. The car does use some oil but im stumped as to why theres no power.....clogged cat?
I drove it about 40 miles today and used 1/4 tank of gas because i have to floor it to get going.
please give me some things to check before i pull the motor and get a new d series!
thanks
Old Dec 11, 2005 | 08:00 PM
92civeg's Avatar
Default Re: PLEASE HELP bought a 91 crx today and it has some engine problems (92civeg)
cmon guys i know someone has some advise
Old Dec 11, 2005 | 08:08 PM
92civeg's Avatar
theres no check engine light on but when i turn the ignition the led in the ecu blinks 5 times then pauses then blinks 15 times
Old Dec 12, 2005 | 11:56 AM
bdavis's Avatar
found https://honda-tech.com/zerothread?id=468260
from https://honda-tech.com/zerothread?id=637661
Old Dec 12, 2005 | 12:32 PM
iakona's Avatar
i would check the timing to make sure it's correct. then check the plugs and fluids.
Old Dec 12, 2005 | 03:12 PM
92civeg's Avatar
but even if the timing belt was 1 tooth off it wouldnt idle smooth..and this car does
Old Dec 12, 2005 | 05:05 PM
tricura's Avatar
Default Re: (92civeg)
the car can idle smooth with being a tooth off. It would throw timing out more then 10 degrees, rev slow and lack power. i would check that, drop the exhaust before cat or have someone put there foot behind the tailpipe to see if it is flowing.
Old Dec 13, 2005 | 04:00 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civeg &raquo;</TD></TR><TR><TD CLASS="quote">but even if the timing belt was 1 tooth off it wouldnt idle smooth..and this car does</TD></TR></TABLE>That depends on which direction it's off.
94taco
Oct 11, 2018 03:43 AM
SisterFister
25
Feb 3, 2010 04:14 AM
allmotor_honda
Oct 10, 2007 08:40 AM
92civeg
14
Dec 13, 2005 08:53 PM
hardcorelolo
10
Jun 2, 2004 11:28 AM
