something that should have been in the FAQ
Old Dec 11, 2005 | 04:33 PM
fcrx7zoomzoom's Avatar
Default something that should have been in the FAQ
I recieved a 93 civic dx (150k miles) and an auto transmission.
I am going to do a 18a1 motor swap and i wanted to know what ecu to use and if i could switch to a manual transmission.
I could'nt find this in the FAQ
Old Dec 11, 2005 | 04:34 PM
SVOboy's Avatar
You can convert the dx ecu to a manual fairly easily, and chip it to run the new engine's maps.
Old Dec 11, 2005 | 04:37 PM
transpar_nt's Avatar
Default Re: something that should have been in the FAQ (fcrx7zoomzoom)
If you want a stock ecu that you won't need to chip you'll need either a p74 or p75 (obd1).
Old Dec 11, 2005 | 04:42 PM
littleredcivic's Avatar
you are better off with the b18b because it is obd1 and available with a hydro clutched transmission. putting an b18a1 will cause you problems when it comes time for smog unless you can find a b18a1 from 1993 and a hydro clutch transmission so you can bolt it up without using the hydro to cable kit.
Old Dec 11, 2005 | 05:10 PM
Default Re: (littleredcivic)
Ideally i would love a b18c but i heard that hey have a clearance issue. The b18b comes out of 1993+ tegs ls? Would that engine also use the p75 ecu?
Old Dec 11, 2005 | 07:20 PM
Everyones Hero's Avatar
Default Re: (fcrx7zoomzoom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcrx7zoomzoom &raquo;</TD></TR><TR><TD CLASS="quote">Ideally i would love a b18c but i heard that hey have a clearance issue. The b18b comes out of 1993+ tegs ls? Would that engine also use the p75 ecu?</TD></TR></TABLE>
OBD-I LS uses a P72 ECU.
Old Dec 11, 2005 | 07:22 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: (Everyones Hero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Everyones Hero &raquo;</TD></TR><TR><TD CLASS="quote">
OBD-I LS uses a P72 ECU.</TD></TR></TABLE>
Uh no. Thats a GSR ECU
OBD1 LS ECU's are PR4 (92-93) and P75 (94-95)
Old Dec 11, 2005 | 07:28 PM
SOHC4life 96's Avatar
Default Re: (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcrx7zoomzoom &raquo;</TD></TR><TR><TD CLASS="quote">Ideally i would love a b18c but i heard that hey have a clearance issue.</TD></TR></TABLE>
Since when? My friends b18c doesn't have any clearance issues in his 92 dx coupe.
Old Dec 11, 2005 | 07:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">Uh no. Thats a GSR ECU
OBD1 LS ECU's are PR4 (92-93) and P75 (94-95)</TD></TR></TABLE>
You're right. My mistake.
I had a chipped P75 sitting in my room for the longest time when I was still thinking about doing a B series swap. Then I started doing research to go turbo I found out that I didn't need the P72 for the B18 because I could chip my P28 and run whatever map I wanted, other than GSR if I wanted to use the secondary butterflies.
Old Dec 11, 2005 | 07:55 PM
nekoabandoned's Avatar
p28 chipped
Old Dec 11, 2005 | 07:56 PM
SVOboy's Avatar
Default Re: (nekoabandoned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekoabandoned &raquo;</TD></TR><TR><TD CLASS="quote">p28 chipped </TD></TR></TABLE>
(this is what I said in the first place)
Old Dec 11, 2005 | 08:16 PM
wob's Avatar
wob
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic &raquo;</TD></TR><TR><TD CLASS="quote">you are better off with the b18b because it is obd1 and available with a hydro clutched transmission. putting an b18a1 will cause you problems when it comes time for smog unless you can find a b18a1 from 1993 and a hydro clutch transmission so you can bolt it up without using the hydro to cable kit.</TD></TR></TABLE>
Old Dec 11, 2005 | 09:04 PM
the b18c will fit just as well as the B18B in an EG with a stock hood. i have a vented hood and i still have enough room to put a big mac and not smash it...i left one in there on accident one time. the B18B will come in the DC style integra. the B18A will come in the DA integras. the preferred ECU to use is the P75.
Old Dec 11, 2005 | 10:41 PM
thanks man. Guess i have more research to do first. I guess almost everything i knew was wrong.
pr_tony_montana
20
Jun 20, 2016 07:18 AM
MattNYC
Feb 1, 2010 09:09 AM
ted
10
Feb 22, 2005 10:04 AM
ted
Feb 14, 2005 03:30 PM
TURBOED-TEG
Sep 16, 2002 07:33 AM
