trunk slammed and now won't close?
Old Dec 11, 2005 | 04:21 PM
UltimX's Avatar
Default trunk slammed and now won't close?
Friend of mine has a crx and his trunk slammed when it was fully opened. Now the trunk doesn't want to lock at all. Any suggestions?
Old Dec 11, 2005 | 05:36 PM
HatchMo's Avatar
Default Re: trunk slammed and now won't close? (UltimX)
in the locking mechinism on the hatch part there is a clasp that goes under the bar on the car it probbaly closed while not being under the bar, its confusing and hard to explain. Take a screw driver and stick it between the lock part on the hatch and pry it open then try closing the hatch again. I hope you understand what im saying
Old Dec 11, 2005 | 05:38 PM
larful's Avatar
Default Re: trunk slammed and now won't close? (HatchMo)
huh
Old Dec 11, 2005 | 05:55 PM
UltimX's Avatar
the locking mechanism is open. The locking mechanism is the part that isn't locking. Thats what I need help with.
Old Dec 13, 2005 | 03:15 PM
UltimX's Avatar
Anyone? I know this has happened to other people. My last resort is to make a new latch for my friend
Old Dec 14, 2005 | 05:23 PM
brodequin's Avatar
i have the same problem.
we figured out the latch wasnt going far enough down to go into the locking mechanism so we put a washer in there to shim it. it worked at first but then it stopped working so i dont know what the problem is
Old Dec 14, 2005 | 05:31 PM
CRX Toad's Avatar
Default Re: trunk slammed and now won't close? (brodequin)
Don't slam the "trunk" or what most of the normal population calls the hatch and it won't screw it all up. Sound like you will need to adjust both pieces now.
Old Dec 14, 2005 | 05:34 PM
SiR Inspired ED7's Avatar
have someone pull the latch while you get latch unstuck, just pull it up a bit. be happy.
Old Dec 14, 2005 | 09:21 PM
UltimX's Avatar
Default Re: trunk slammed and now won't close? (88 Crx Si)
it wasn't my fault, and it isn't my hatch. We've tried to adjust both pieces but it doesn't work. the only part you can adjust is the actual latch part and not the mechanism.
88crxsi: it isn't locked shut, it won't latch, thats the problem.
Anyone else have any ideas? I'm sure someones figured it out. At first I thought it was the mechanism, but it isn't. I got one from a junk yard and it still doesn't work. I'm guessing i'm going to have to make a new latch?
Old Dec 18, 2005 | 01:29 PM
brodequin's Avatar
still messin with it
bump
Old Dec 18, 2005 | 01:42 PM
UltimX's Avatar
Default Re: (brodequin)
Me too. The last thing I want to have to do is make a new freakin hatch latch. I don't think I can weld on the stock one because it looks like it is plated with something. Bump for help!
rafaello
Aug 29, 2020 05:58 PM
Braco11
14
Feb 23, 2007 01:39 PM
M15
Aug 7, 2005 04:31 AM
DeDonDeRosa
Jan 22, 2004 10:38 AM
Alexander
May 24, 2002 01:03 PM
