New Bulbs for Gauge Cluster ??
Alright, I got my Red bulbs, took the 2 screws off on the front top of the cluster
What esle do i take off to change the bulbs ????
PLZ HELP .... Wanna get this done tonight PLZ
Thanks
Thanks
after you got the two screws out.
there are 3 additional screws you can see.....
left right and like...uptop...inside the thing
take those out..and slide out the cluster....it should just slide out...and there are three
screw out things where the bulbs go...screw em out..and replace...then screw everything back in...and your good to go!
im me if you need anymore info.
i got the 2 off the front... i cant see any others and it looks like its connect to the whole bottom portion of the dash....( where the vents and stuff are )
IM CONFUSED !!
IM CONFUSED !!
there is one...like in the middle...not on the cluster...but its a little plastic flap...from like the middle uptop...unscrew that one.....and then slide it out...
by the way....what year is your car...lol...
OK>>>> i found something Installing Gauge Cluster.
INFO... 90-93 Teg Gauge ....
Well it'll be hard to mention where every screw is but I'll tell you the area where they are:
1-Two or three screws (upside down) on the dash in front of the cluster.
2-Pull a/c ***** out and pop the little a/c dash (showing a/c fan speed and temp) out .There's going to be one or two screws back there.
3-There's a little triangular plastic piece on the right of the a/c stuff closer to the passenger side, pop that out and you'll see one more screw.
4-Take off the big plastic cover right at you knee and you see four or five screws upside down holding the dash board.
5-Now all the screw should be out ,use flat edge screwdriver to pop the dash out and use force because there are clips all over the place and they'll pop out with some force but don't break anything.
For cluster:
1-Once the dash is out there are two golden screws holding the cluster to the car, take them out.
2-Pull cluster back , stick one hand back there and detach two big electric plugs on the left upper corner (when looking through the steering wheel). These plugs have a clip, push the clip and pull the plug at the same time.
3-Pull cluster more and there will be a thick cable in the middle bottom of the cluster with a clip, push clip and pull cable backwards (this will be kind of hard)
For cluster:
