1989 HOnda CRX HF
Old Dec 11, 2005 | 03:04 PM
trip1202's Avatar
Default 1989 HOnda CRX HF
D15b6 motor is SHOT! looking into getting more HP with an easy swap! What would you all recommend? How easy is that motor to swap? Any mods?
Old Dec 11, 2005 | 03:07 PM
kulangot's Avatar
Default Re: 1989 HOnda CRX HF (trip1202)
https://honda-tech.com/zerothread?id=1325660
Old Dec 11, 2005 | 04:22 PM
trip1202's Avatar
Default Re: 1989 HOnda CRX HF (kulangot)
Will the HONDA CIVIC 1600 SOHC VTEC (=D16Z6) swap out directly without no transmition changes or wiring harness changed?
Old Dec 11, 2005 | 10:36 PM
killa rex's Avatar
i did that swap in my 91 CRX HF...used pgmfi.org for the wiring(obd0-obd1)..91 SI tranny..92+ cat..88-91 CRX DX/SI e-pipe(had to cut the end off and replace it with the HF, it mounts differently and the end)..used all the stock mounts
Old Dec 11, 2005 | 11:24 PM
trip1202's Avatar
Default Re: 1989 HOnda CRX HF (xmunxjai648)
WHat if any recommendations would be the best engine to swap the d15b6 to? I want more HP but i dont want to have to get a new transmittion..... I dont want a massive hp car but anything about 100 is better than 62.. any reccomendations???? im open to them.......and i need them asap ! thanks
Old Dec 12, 2005 | 05:23 AM
B18aHatch's Avatar
just find a si head from a 89-91 civic/crx. and drop it on. that will bring you from 60hp to 109?. there kinda cheep too....or just swap in the whole si motor. plops right in.
with the z6 u have to do wirring for obd1 so you have to convert. and you need to add wires for vtec and the o2 sensor. and get a new computer too...
Old Dec 12, 2005 | 05:47 AM
md88hfcrx's Avatar
Default Re: (B18aHatch)
A6 motor swaps right in.
i would suggest a Si tranny but its not a must. it would just be quicker.
Old Dec 12, 2005 | 07:03 AM
trip1202's Avatar
Default Re: (md88hfcrx)
Ive been told you have to get the si computer for it to run right........are they just giving me the run around or is that true?
Old Dec 13, 2005 | 02:11 AM
killa rex's Avatar
Default Re: (trip1202)
i think i had a pm8 or p8m(whatever the code was) in my HF..isn't the SI the same ecu??
Old Dec 13, 2005 | 03:31 AM
crxnj's Avatar
Default Re: (xmunxjai648)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18aHatch &raquo;</TD></TR><TR><TD CLASS="quote">just find a si head from a 89-91 civic/crx. and drop it on. that will bring you from 60hp to 109?. there kinda cheep too....or just swap in the whole si motor. plops right in.
...</TD></TR></TABLE>
What are you talkin about..? The hf pistons have valve reliefs made for an 8 valve head,,and the si head is 16 valve..He would also have to swap out pistons to pistons to do this head swap..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xmunxjai648 &raquo;</TD></TR><TR><TD CLASS="quote">i think i had a pm8 or p8m(whatever the code was) in my HF..isn't the SI the same ecu??</TD></TR></TABLE>
No its a different code and has different fuel/timing maps ..SI ecu is PM6..
I think you should a whole 89-91 si d16a6 swap..Motor,tranny,ecu..Everything bolts in place and it'll be a big difference going from the hf motor to this..Around here people sell these whole swaps around $200 or less..Do an intake, header, and exhaust an be done with it..
Old Dec 13, 2005 | 05:03 AM
90efcivic's Avatar
Default Re: (Mr.speaker)
i agree go with the whole motor
Old Dec 13, 2005 | 05:24 AM
B18aHatch's Avatar
yea forgot bout those 8 valves. i did that a6 head on my dx block. so um ya dont listin to that sugestion. just do the whole motor.
but u can find a si ecu for cheep, i see them alot for not much. check on ebay and on the forsale fourms..
Old Dec 13, 2005 | 08:55 AM
godruler's Avatar
hey,i drive a '91 Hf and two weekends ago i swapped in a '95 D15B7 motor which is a baseline '92-95 Lx/Dx motor, i think its like 102hp at the crank or so. its a very easy swap bolts right in and i bolted my Hf tranny up to it no problem (temporary until i fix my Si tranny). I kept the motor Obd0 using a PM6 from an '88-91 Si. its a very easy swap and had good results, definate power improvement.
Old Dec 14, 2005 | 12:10 AM
StorminMatt's Avatar
Well, one nice thing about an HF is that ANY motor you swap in is going to be an improvement.
Old Dec 14, 2005 | 07:12 PM
trip1202's Avatar
Default Re: 1989 HOnda CRX HF (StorminMatt)
THANKS ALOT EVERYONE!!!! I actually bought the zc dohc and tranny to put in it because i got a good price it came with the ECU also not sure if i need to put it in or not? any suggestions of stuff i need to know before i tackle putting it in? AND AGAIN THANKS ALOT FOR EVERYONE'S HELP!
Old Dec 14, 2005 | 07:21 PM
EF_338's Avatar
sweet that what i was going to say
where did you get the motor from??
im going to get mine from hmotors
anyways here is a link for you and your ZC
it will tell you all you need to know
plus if your using a ZC tranny
you will need to change your axles
"The ZC trans. requires you to use ZC or 90-91 Integra axles, and a ZC intermediate shaft. Because these axles are equal length, many users report a reduction in torque steer."
http://www.thezcr.com/forums/showthread.php?t=7334
Old Dec 14, 2005 | 08:00 PM
ryan89crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trip1202 &raquo;</TD></TR><TR><TD CLASS="quote">THANKS ALOT EVERYONE!!!! I actually bought the zc dohc and tranny to put in it because i got a good price it came with the ECU also not sure if i need to put it in or not? any suggestions of stuff i need to know before i tackle putting it in? AND AGAIN THANKS ALOT FOR EVERYONE'S HELP! </TD></TR></TABLE>cake swap. get some dx or si hubs because you will need 90-93 axles and they wont work with the HF hubs. use the ECU that comes with the ZC, its simple to switch out. pull the carpet back on the pass side, remove the 4 10mm nuts, remove cover, and swap the harness to the new ECU.
your stock HF harness will work fine, there will be an extra plug that you wont use which is for the EGR, just let it hang. there will also be a couple extra vacuum lines(EGR again) i just plugged mine and it works fine. or you could do it the "right" way and get an SI map sensor, lol.
you will also need to add a couple wires for the CPS, try this http://rywire.com/store/produc...45208
hope this helps
Old Dec 14, 2005 | 09:02 PM
trip1202's Avatar
Default Re: 1989 HOnda CRX HF (ryan89crx)
cool man i ordered the wires from that site.... do you know where i can find the hubs?
Old Dec 14, 2005 | 09:25 PM
ryan89crx's Avatar
junkyard
MastaFlyMason
Jul 26, 2017 06:49 PM
capone478
Classic Hondas
16
Apr 11, 2011 05:35 PM
doezitmater
Mar 29, 2011 10:05 PM
importgod21682
Dec 15, 2005 06:34 AM
