How does the ECU determine when the vehicle is "cold" for cold start ups?
Old Dec 11, 2005 | 01:53 PM
rice is nice's Avatar
Default How does the ECU determine when the vehicle is "cold" for cold start ups?
fixed
Modified by Beef-Cake at 4:01 PM 12/12/2005
Old Dec 11, 2005 | 02:16 PM
drdisco69's Avatar
Default Re: How does the ECU determine when the vehicle is "cold" for cold start ups? (Beef-Cake)
The coolant temperature sensor reports what it sees, and the ecu follows a curve of temperature vs. fuel correction for various temperature points. The idea is more fuel to warm the car up and not stumble due to cold parts, and it idles the car higher for the same reason.
Old Dec 11, 2005 | 11:25 PM
-ILLICIT-'s Avatar
i remember reading something(in HT) about a relay that can stuff up only once its heated due to solder expansion...not sure if thats the case with yours might be worth checking out....sorry no i dont know the name of the relay, something to do with the ignition though...
Old Dec 12, 2005 | 10:34 AM
JimBlake's Avatar
It's hard to handle a broad question like this because so many things change over the years. My dad's 1977 Civic didn't even have an ECU.
Depending on what year, there's also the FITV. If your car is old enough to have one of those, it pretty much works by itself without the ECU's help.
But the ECU measures air temperature (IAT sensor) and coolant temperature (ECT sensor).
Jmarteggy
May 16, 2019 05:44 PM
mattcxb18
Dec 15, 2002 07:21 PM
Kataku2K3
Nov 22, 2002 06:02 PM
1hottEG6
May 6, 2002 01:43 PM
Faust
Apr 17, 2002 04:47 PM
