iv search lil bit help. need more
i got code 14 stayn on.
iv cleaned mine and still showed up
and i even put a new iacv on and still idle bout 1500rpms
can u guys help me more in fixn it
it fail expection last year. so help out so i can pass
Mind reworking that ? I could be a douchebag here but I know what it's like to depend on HT and not get a response due to being overlooked by the "check out my new rotas that look just like that other car' threads.
Problem: Youre throwing code 14. Car is idling at 1500RPM. Fails inspection (obviously with a code)
You have tried: Cleaning and replacing IACV
Maybe try getting a voltmeter and testing all your wires out that are related to that sensor. My car was down for a while with me trying to figure out a distributor problem (replaced dizzy and all) and it ended up being the insulation worn off the wire and grounding it at the firewall.
good luck
good luck
aitht man i did it and it still comes up da engine light.
ne thing else that u can think of to fix da problem????????
let me know
let me know
u mean unhock it form the battery or where the wires hock up to the ecu??????
if unhocking the battery NOPE!!!!!!!!!!!!! , did that to still came back
jus dont thing my car likes me
UNDER PRESSURE
Nov 21, 2005 02:19 PM
