USDM dash conversion to JDM dash
Hi. My USDM EL gaugues are damaged so I bought another one that was a JDM EL dash. Has anybody done this, anybody know what wires have to be modiefied for it to work properly and fit. Thanks!
hi
i have a jdm speedometer that is converted to miles but i need a kilometer speedometer
maybe we can interchange our speedometers if you want
my speedometer has 49.000 mls and goes to 180 mls
how much kilometers do you have ?
No it doesn't plug right up because the plugs are different.
How did you get to install it? I know you have to splice some wires and connect the to the jdm plugs but I need like a wiring diagram or something.
Modified by NeriVTEC at 9:00 AM 12/12/2005
HEre's what I did
First the JDM & USDM are diffrent in the back due to the USDM being slightly curved on the left b/c it's on the left side and the JDM one being curved more to the right b.c it sits on the right side.
So, what I did was take off the JDM backing of my KMH speedo and did the same with the USDM MPH speedo backing. Then I put the USDM Mph backing on the back of the JDM kmh speedo cluster. Then plugged it all in a boom it worked.
Before I became smart enough to do that I extended and sauderd the wires on my USDM to reach the apropiate spot on the cluster. That was just to much. Worked, but to much.
If you take off the backing's it will work.
Beau Gotti
Jan 8, 2007 02:06 PM
