Tie rod end boot replacement
Old Dec 11, 2005 | 12:04 PM
mc's Avatar
mc
Default Tie rod end boot replacement
I am in the middle of replacing the tie rod end boot. I got the new boot on but when I try to tighten the castle nut the threaded shaft just spins. What is broken or what am I doing wrong here.
TIA
Old Dec 11, 2005 | 01:17 PM
IN VTEC's Avatar
Default Re: Tie rod end boot replacement (mc)
Tap the treads on the castle nut to clean them up/straighten them out. Clean the threads on the balljoint to remove any debris that the nut might snag on while tightening it.
If it really comes down to it, use a pair of pliers or vise grips to clamp the outer tie rod down onto the knuckle, then impact it or tighten it with hand tools.
Use anti-seize.
HuskerHybrid
33
Dec 19, 2006 08:22 PM
atg1290
Sep 3, 2006 03:55 PM
kroze
Jan 2, 2006 06:20 PM
THE LORD OF CHAOS
Nov 6, 2005 11:12 AM
SVOboy
11
Sep 18, 2005 05:09 PM
