Help with check engine code.....OBDII - P0420/ MIL 67
Old Dec 11, 2005 | 10:04 AM
mitchb's Avatar
Default Help with check engine code.....OBDII - P0420/ MIL 67
OK when you use the jumper wire to check the codes with the check engine light it reads 67. Which is OBDII P0420, and that reads (Catalyst System Efficiency Below Threshold) What the hell does that mean, and how can i fix it.
Old Dec 11, 2005 | 10:15 AM
erasable180's Avatar
Default Re: Help with check engine code.....OBDII - P0420/ MIL 67 (mitchb)
probably need a new cat or new o2 sensor
prwittman
Jul 13, 2018 01:00 PM
Meemo Foo!
Jun 16, 2016 02:37 PM
Tru2Less
Dec 31, 2007 07:17 AM
ZeroEric
Aug 10, 2002 04:36 AM
