dust sheild needed?
ok i jus put some coilover on and the dust sheild is jus sittin on top of the coilover and makes the car sits higher than stock....do i need the dust sheildon the shock?
Do you mean the dustboot? That black rubber sleeve with the accordion-section that protects the piston rod? Its basically a flimsy piece of rubber that you can compress with your fingers, I don't see that it would affect your car's ride height.
edit: Looks something like this:
here a site wit some pic https://honda-tech.com/zerothread?id=1449932 (the 2 on the outer side. the metal inside the spring
the pic u post have rubber instead of metal.....maybe the rear have rubber...havnt gone to the back yet
Modified by aznteg at 2:08 PM 12/11/2005
Some of the cars did have a stock steel dust cover and they can hit an aftermarket coil-over sleeve. You can either remove it or cut it shorter so that it does not hit. This is a common issue with drop-on coil-over sleeve its.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznteg »</TD></TR><TR><TD CLASS="quote">yea i finally took it off...and left it off....but wont it cause the shock to act the way they should after awhile... </TD></TR></TABLE>
it's not a big deal, though ideally it'd be nice to have a dust boot back there.
instead, you can just clean up your shocks and springs once in a while to compensate...
Jaydeep
Jul 26, 2005 12:57 PM
