Finished swapping blocks....Motor won't stay alive... Help!
Old Dec 11, 2005 | 09:26 AM
I3ooS710's Avatar
Default Finished swapping blocks....Motor won't stay alive... Help!
I posted in my previous thread about swapping my B16A block with a B16A2 block due to broken ringlands.
The motor I got seemd to be in good shape although there was a tiny bit of rust around the cylinder walls. I got that off and proceedeed with the swap.
After finishing the swap, I tried to fire her up but the motor shook horribly and if something was about to break. The only way the car would stay on is if I gave it gas, and even then, the car shook horribly and had an extremely rough RPM levels.
Light but thick smoke came out of the exhaust. I smelled a lot of fuel..
I pulled out the plugs and they were wet. The plugs also smelled like fuel.
I did a compression check and here were my numbers...
1- 215
2- 210
3-210
4-215
Every single bolt was torqued down to the correct specs when reassembling the motor...
Any idea what MIGHT be wrong?
Thanks in advance.
Old Dec 11, 2005 | 09:50 AM
drdisco69's Avatar
Default Re: Finished swapping blocks....Motor won't stay alive... Help! (I3ooS710)
What car? Check engine light on? I don't think it's a mechanical issue.
Old Dec 11, 2005 | 11:40 AM
I3ooS710's Avatar
Default Re: Finished swapping blocks....Motor won't stay alive... Help! (drdisco69)
Thanks for the reply. I pulled off the valve cover and noticed that the timing was off by a few teeth marks.
I reset everything including the crank pulley to TDC and it seems to be doing ok now.
However, on another note, the car is a turbo B16A. It hasn't been driven since the swap.. But is there a possibility that the motor still might need to burn off the old oil because my car is still smoking a bit when the throttle is pressed... I'm going to put the wheels back on and let it idle for a good 20 min to maybe burn off the old oil that's been sitting in there... But is it a possibility it might be something else?
Old Dec 11, 2005 | 11:59 AM
drdisco69's Avatar
Ha, I suck at diagnosing cars over the internet.
Old Dec 11, 2005 | 02:20 PM
I3ooS710's Avatar
lol...How many quarts of oil do I put in after a fresh swap? I put 3.75 quarts in, but my oil light is on now. I checked the oil level and it looks really low. I don't understand why.
I put more oil in and saw the oil level coming up. However, the light is still on. What I don't understand is why is the light still on when I know there's about 4 quarts in the motor? When putting together a new motor, is there MORE oil required?
Also, the oil sending swich is connected, so I don't think that's the reason why the light is on.
Old Dec 11, 2005 | 11:18 PM
93EG6SI's Avatar
the oil "level" light is actually an oil pressure light, you have an oil pressure problem.
Old Dec 12, 2005 | 06:37 AM
I3ooS710's Avatar
Default Re: Finished swapping blocks....Motor won't stay alive... Help! (93EG6SI)
It's possible that it could be an oil pressure problem but I've read on other threads that it could possibly be the oil pump or a clogged pump pipe/tube. Anyone know the symptoms of these?
Old Dec 12, 2005 | 08:04 AM
Golden Eagle's Avatar
sounds to me like a bad oil pump i would change it
Old Dec 12, 2005 | 10:09 AM
I3ooS710's Avatar
Default Re: Finished swapping blocks....Motor won't stay alive... Help! (Golden Eagle)
I'm going to drop the pan tonight and see if anything thing is clogged or blocked. This block has been sitting forever so there MIGHT be something clogging the suck tube (I don't know what it's called). If that is totally clean and free of any debri, I will change the oil pump.
aavtec
19
Feb 18, 2013 04:20 AM
TurboSpoolinInside
Jun 19, 2010 11:25 AM
spddmn2198
Dec 22, 2007 03:57 PM
subaruwrx88011
Aug 28, 2007 04:23 PM
TURBO
13
Jul 10, 2004 04:23 PM
