odyssey pc 680 install with small problem?
Old Dec 11, 2005 | 08:49 AM
ppfalcon's Avatar
Default odyssey pc 680 install with small problem?
Ok have a bit of problem I finished installing my odyssey battery and the problem I am running into is I am blowing 60 amp fuses. It does not blow the fuse when i first put it in only when I turn the car off and try to restart it. What happens is the engine tries to start and then fuse blows? Now like I said this only happens after I start the car with a good fuse, start it, drive it, turn it off, and then try to start it again, and bam blown fuse?
Now one thing is that the fuse holder I am using accepts 6-gauge wire and the wire to the battery is 4-guage, so what i did was splice the 4-gauge wire and installed the 6-gauge wire and fuse. so it goes like this
battery--4-gauge to 6-guage to fuse holder with 60A fuse to 6-guage to 4-gauge.
any help would be nice..
I am going to try and find a fuse holder that accept 4-gauge wire as I think my problem is the 6-gauge wire spliced.
Old Dec 11, 2005 | 10:36 AM
ppfalcon's Avatar
Default Re: odyssey pc 680 install with small problem? (ppfalcon)
No one has ever installed an odyssey battery?
Old Dec 11, 2005 | 12:49 PM
DelSolDon's Avatar
my thoughts would be that you are grounding out somewhere, probably with one of your splicings. also, are you sure that the fuse is supposed to be 60amp? i could have sworn the fuse was 80amp, i could be wrong though. when you start it the first time, are you starting it with the hood open? and i assume that when you try to start it the second time, the hood is shut?
Old Dec 11, 2005 | 01:14 PM
VegaS10's Avatar
Pretty sure it's too much current draw. Most starters require more than 60 amps.
Try a larger fuse holder/fuse.
Thepowderblue
May 23, 2012 02:30 PM
civiccoupe94
Sep 19, 2008 01:27 PM
boostedb18kid
Jan 18, 2008 08:29 AM
TorquelessB16
Audio / Security / Video
Jun 5, 2006 05:28 PM
merch1
Mar 6, 2005 11:07 AM
