Play in Clutch
Old Dec 11, 2005 | 07:07 AM
aidanodr's Avatar
Default Play in Clutch
Hi Guys,
I live here in Cork, Ireland. I recently bought a Japanese import Integra. Black, unmodded, 1.6, 1998. Alls fine, but for the following, I would appreciate your input:
I move off in first and then as i put the car into 2nd gear the car gives a slight jerk/shudder - not too far away type of feel that may happen pre stall. However if I let the Clutch out very slowly alls fine. Its as if the clutch is very sensitive. This is not so bad if not occurent, when in 3rd etc. I notice that the clutch when depressed has about an inch of play [ "loose" ] before point of engage [ if this is the right phrase, this when the car is in or out of gear. Its as if the clutch needs 'tightening'. If I look up underneath the stearing Wheel area dash section at the 'top' of the clutch pedal, I notice a bolt which can be adjusted.
Please note Im not a car expert by any means, so go easy on me with the tec stuff
Heres a shot of the car, at night, not great, but gives you an idea:
http://tidalsound.com/3dstuff/newcar.jpg
Cheers
Aidan O Driscoll
Old Dec 11, 2005 | 12:41 PM
Lauj87's Avatar
sounds like your clutch is slipping, time for a new one!
Old Dec 11, 2005 | 01:18 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Play in Clutch (aidanodr)
Try bleeding the slave cylinder on the transmission. You may have air in the line causing a spongy pedal.
If you need a manual, check out the following site:
http://www.hondahookup.com/manuals
Parptarf
Apr 8, 2015 05:36 PM
harmonator84
Transmission & Drivetrain
Aug 28, 2008 10:14 AM
aidanodr
Dec 11, 2005 08:03 AM
dexy
Jan 11, 2005 09:53 AM
Flux
Nov 26, 2003 11:25 PM
