0.5mm or 1mm oversized valves?
Old Dec 11, 2005 | 04:48 AM
mrx's Avatar
mrx
Default 0.5mm or 1mm oversized valves?
Hallo,
is there any reason why i shoudn't take 1mm oversized valves? are there any disadvantages with them against 0.5mm oversized valves?
Thanks
Malte.
Old Dec 11, 2005 | 04:53 AM
Runnerdown's Avatar
Default Re: 0.5mm or 1mm oversized valves? (mrx)
Whats the motor setup. Oversize valves are beneficial mainly on wilder engines.
Old Dec 11, 2005 | 04:59 AM
mrx's Avatar
mrx
Default Re: 0.5mm or 1mm oversized valves? (Runnerdown)
it is for a B16A1 Turbo engine... i want to do something to help the engine breath better especialy on the low/mid range before boost and was asking me if i could have any disadvantages from taking 1mm oversized valves.
Old Dec 11, 2005 | 08:09 AM
Fkned's Avatar
You can add them but it's not needed.I did a head that's gone 9.6's with the stock valve sizes.
Old Dec 11, 2005 | 08:13 AM
mrx's Avatar
mrx
Default Re: 0.5mm or 1mm oversized valves? (Ed's Racing Heads)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ed’s Racing Heads &raquo;</TD></TR><TR><TD CLASS="quote">You can add them but it's not needed.I did a head that's gone 9.6's with the stock valve sizes.</TD></TR></TABLE>
what else did you do on the head if you leave the valve size stock?
if you only done some other headwork, i guess bigger then stock valve size doesn't increase the airflow?! so they aren't a bottleneck at all... right?
Old Dec 11, 2005 | 08:18 AM
Used2beAb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrx &raquo;</TD></TR><TR><TD CLASS="quote">
if you only done some other headwork, i guess bigger then stock valve size doesn't increase the airflow?! so they aren't a bottleneck at all... right?</TD></TR></TABLE>
You can get a valve job w/o going oversized.
Old Dec 11, 2005 | 08:22 AM
Fkned's Avatar
I fully ported the head if that's what your asking.The problem w/bigger valves is that it limits the cam choices you can make.It used to be that turbo cars ran stock itr/gsr cams now they are finding more power w/aftermarket longer duration higher lift cams so it becomes an issuse then.
flycatcher
Apr 26, 2009 10:03 PM
slowtegkauai
Apr 12, 2008 01:37 PM
Suzukii
Oct 24, 2005 12:17 PM
Smoothy
Sep 23, 2001 05:38 PM
