Snapped a Belt
Well, I was driving today and I snapped a belt. I popped open the hood and found out it's the one that drives the a/c compressor. I am assuming that there is no risk of damage if I continue to drive the car for the time being. Is that a safe assumption?
during the winters, i just take off the a/c belt for better gas mileage and acceleration, and dont want to wear the belt out faster on my old civic.
then in summer i just put it back on since i sometimes need it, so you'll be fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccoupe94 »</TD></TR><TR><TD CLASS="quote">during the winters, i just take off the a/c belt for better gas mileage and acceleration, and dont want to wear the belt out faster on my old civic.
then in summer i just put it back on since i sometimes need it, so you'll be fine</TD></TR></TABLE>
It's good to run your A/C during the winter every other week. The reason you do this is to make sure all the parts get lubricated. Have a compressor just sit there for 8 months without moving can lead to seizing.
Gas milage should only be effected with the A/C is actually on.
I had my AC belt come off this morning on the way to work. As I can see from this thread I should be fine to drive.
But my belt did not snap, it jumped off the AC b/c the pulley above seized. Belt is still on the car since it is around the lower driver's side engine mount. So should I cut the belt off or just pull it to the side till I get home?
And when I replace the belt do I have to remove the lower engine mount to put it on?
BTW b18c1 in a EG.
TIA
edit: And I know I should not run my AC, but is it OK to run the heater.
Modified by fakemike at 9:39 AM 12/28/2005
BTW b18c1 in a EG.
TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 »</TD></TR><TR><TD CLASS="quote">i'd check my other belts while you're at it. just to make sure nothing else is loose/tight.</TD></TR></TABLE>
I will do that. So should I just cut off the loose AC belt and replace it in the summer?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fakemike »</TD></TR><TR><TD CLASS="quote">
I will do that. So should I just cut off the loose AC belt and replace it in the summer?</TD></TR></TABLE>
just replace it when you have time... all my belts snapped or fell off at one point and my ac pulley fell off and rolled down the street. made me laugh.
srv3fender
Mar 1, 2005 05:18 AM
