Removing foglight case?
How do i remove the foglight case(housing?) i forgot what you call it...im tryn to do a diy fog light by painting the bulb with stain glass paint..but i cant remove the bitch...i read around saying you got to remove a screw in the middle or something but i cant find it...any diagrams someone can show me or pictures?
oh yeah 91 integra
oh yeah 91 integra
I'm not sure on how to do it. But have you tried http://www.g2ic.com
They have a bunch of how to's in the teg tip's section.
Ali
Ali
Its actually really easy, took me a bit to figure it out, but the best way to explain it, is there is a little screw in the middle, the one on the passenger side will be behind your little stock air intake thing, and the one on the drivers side should be in the same spot, unscrew these little screws, or maybe your missing them, but after the screws are out, it just kinda pops out of place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spectrum24x »</TD></TR><TR><TD CLASS="quote">Its actually really easy, took me a bit to figure it out, but the best way to explain it, is there is a little screw in the middle, the one on the passenger side will be behind your little stock air intake thing, and the one on the drivers side should be in the same spot, unscrew these little screws, or maybe your missing them, but after the screws are out, it just kinda pops out of place.</TD></TR></TABLE>
well i havent checked that yet..but i can like almost pop the whole unit out of place but i guess that little screw is keeping it on?
but the only screws i see is behind the main (middle?) light..only thing behind the fog light is the radiator??
Ok, your looking at taking out the whole headlight housing. you just want to remove the foglight case right?
Ok, where i made the black circles, there should be two little screws there that just hold it tightly in place, if you losen those, you can just pull the whole casing out, if you can't find these, just yank on the casing, and wiggle, it'll come out...
The screws and bolts you pointed out and are looking are are to remove the whole housing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N.O.R.E »</TD></TR><TR><TD CLASS="quote">
well i havent checked that yet..but i can like almost pop the whole unit out of place but i guess that little screw is keeping it on?</TD></TR></TABLE>
If you can pop the case out of place, but can't pull it out, you need to pull the wiring harness out, it's a tight fit on wiring, and that will hold it in place
If you can pop the case out of place, but can't pull it out, you need to pull the wiring harness out, it's a tight fit on wiring, and that will hold it in place</TD></TR></TABLE>
can i pull the wiring harness out when i pop the foglight out or something else to it?
ahh nm i got it...did it last night...looks alittle flush but will krylon stain glass paint last from the heat of the bulb? or do i have to redo it every few days-months? or should i just get a bulb, and who makes them?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spectrum24x »</TD></TR><TR><TD CLASS="quote">you wanting yellow fogs?
you could probably buy a yellow bulb, otherwise, id say just get jdm 1pcs.
I just got mine and i love them</TD></TR></TABLE>
where can i get the yellow bulb from...cuz my **** melted when i was leaving work...i think it lasted like 2miles?
88ernie88
13
Apr 5, 2009 12:31 AM
ryan_long_01
Aug 19, 2006 12:37 PM
RTW DC2R
Dec 23, 2002 01:33 PM
