GSR MOTOR INTO LS TEG PROBLEM
Old Dec 10, 2005 | 06:20 PM
Team Rukus's Avatar
Default GSR MOTOR INTO LS TEG PROBLEM
Hey guys.
Got a B18C motor out of an ek and I am intstalling it now into a 95 Integra.
My question is regarding the mounts...
I am using all the stock mounts and brackets that were on the integra (had an ls motor) except for the rear mount bracket it came with the new B18c motor. Now I am assuming it had a 99-00 SI mount bracket for it since you need it to install the GSR into the ek.
My question is do I have to switch the rear mount bracket to the stock ls bracket too or can I keep the rear SI mount bracket?
And if I switch it over if it needs to get switched will that let me bolt the motor up to the car or do I still have to do anything else to it?
And when installing a motor what mount/bracket bolt do you guys attach first?
Whats your process on it? do you attach the rear bracket to the subframe and then install all the mounts on the motor to the car and then install the rear bolts to the block or do you install the rear bracket to the motor and then install the bolt into the rear mount and then install all the mounts to the car???
Any help is appreciated guys.
P.S i did some searches but couldnt find definate answers specific to my question.
posted in hybrid but no replies so i posted here for more exposure
Old Dec 10, 2005 | 06:41 PM
2SlowDC's Avatar
be sure to take the driver side mount off b4 lowering it into your car. i usuallly hook up the rear bracket first. get a jack under the engine to position the mounting points.
Old Dec 10, 2005 | 09:40 PM
mattcivic's Avatar
Default Re: (No-Tec)
use yer stock rear bracket the SI one wont work sell it on ebay or something.
Old Dec 11, 2005 | 09:25 AM
Team Rukus's Avatar
thanks guys.
zccrx
10
Dec 27, 2007 09:19 PM
whitehf
Jun 17, 2006 04:40 PM
Team Rukus
Dec 12, 2005 12:15 PM
Hatchd
Jun 22, 2005 04:00 PM
crxhybrid1320
Apr 20, 2003 07:00 PM
