header again
ok, so we put my header on tonight, it went on pretty easy, i had to extend the wires for the O2 sensor, but it all went good. I turned it on, but had a check engine, i guess this is normal, so i disconnected the battery, and it works fine now, i just have a few places I may have some air leaking, can someone else tell me some other things to watch, and problem areas for leaks?
thanks
austin
thanks
austin
Did you use a brand new exhaust manifold gasket? The old one may have formed with the old manifold due to heat and pressure...it's recommended to use a new gasket each time. Otherwise, gaskets between the header and the rest of the system may clear up some leaks too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordselux »</TD></TR><TR><TD CLASS="quote">Did you use a brand new exhaust manifold gasket? The old one may have formed with the old manifold due to heat and pressure...it's recommended to use a new gasket each time. Otherwise, gaskets between the header and the rest of the system may clear up some leaks too.</TD></TR></TABLE>
no, it's not that, i can almost bet on it.
let me guess, it's a 6th gen obd2 which will throw a code 41 which is pretty common when you entends the wire, heater circuit malfunction cel will come on.
ok, can someone explain obd2 to me lol, i dont know what this is, what can i do to make sure i get everything tightened right, what torque should i go to, and some other tips. I dont want to burn a gasket or anything.
austin
austin
Plus the basic computing system is more complex. OBDII was initiated to reduce emissions even further, this way the computer can monitor emissions pre and post cat and make more changes.
jdmstockeg6
Sep 25, 2007 12:21 AM
gtowni3
29
May 12, 2005 03:14 PM
