Fan running after car turned off?
Old Dec 10, 2005 | 05:56 PM
CrashCymbol's Avatar
Default Fan running after car turned off?
I've got a 90 EXR and I have a very strange problem with the fan. When I turn the car off, the fan keeps running. And it doesn't stop. If you disconnect and reconnect the battery overnight, the fan still runs. Some of my friends thought it might be a fan relay.. but I'm not sure. What do you think it could be?
Old Dec 10, 2005 | 07:20 PM
P_Adams's Avatar
Default Re: Fan running after car turned off? (CrashCymbol)
It will turn out to be either the Cooling Fan(s) Relay, or the Thermal Switch that controls it (mounted near thermostat housing)
P
Old Dec 10, 2005 | 11:21 PM
deserthonda's Avatar
first off make sure the rdiator is full.. if it is ok,, it could be the switch at the end of the top radiator hose ,,,,
The switch at the thermostat housing controls the fans ( both fans ) operations when car is running and at operating temp ( coolant is warm enough ),,,
Old Dec 11, 2005 | 11:42 AM
hondadude's Avatar
Diagnose the problem, the thermal switch that is mounted in line with the upper radiator hose, find it and unplug the connector, if the fan shuts off you have found the trouble
Old Dec 11, 2005 | 02:22 PM
Ross 2.0's Avatar
In a Junkyard near you.
Actually I believe that car is equipped with a cooling fan timer that likes to take a slow and random crap. If you have one it's mounted right under your glovebox. It's a black box that says coolig fan timer on it. If you can't find it right away you may need to take out the two 8mm bols holding your glovebox on, pull the box out and you'll see it right there. I'm pretty sure that was the first year Honda used that on Accords.
f15Civic
Mar 9, 2017 05:45 AM
MyRed98Civ
Jan 11, 2014 06:51 PM
kai-chun
12
Sep 8, 2006 03:20 PM
ekfighter
Aug 6, 2004 07:33 AM
ATS*Mark
Dec 9, 2003 11:08 PM
